Ceska Posted March 6, 2017 Share Posted March 6, 2017 (edited) Hi I have Recording service in use. Id like to use DVBViewer from my laptop outside LAN. Ive made port forwardings to router. RTSP Service Device? port 554, UDP-ports 52000 - 52100 outside LAN? Also DDNS is in use. xxxxxxxx.xxxx.xxx:8089 DVBViewer finds recording service in Options when push "test connection" Also EPG timeline found No Picture though. What should i do? Works fine from another DVBViewer in LAN from bedroom. How i share home network to outside LAN use to my Laptop? Edited March 6, 2017 by Ceska Quote Link to comment
Tjod Posted March 6, 2017 Share Posted March 6, 2017 Don't expose other ports then the web interface port to the internet. The other not web server based steaming method's are only designed for the LAN use. Then the first thing to check is the internet upload speed from the PC with the RS. If it is 10 Mbit/s or more a VPN between RS PC and the laptop could be a solution. Quote Link to comment
