DAB or DAB+ support in DVBViewer
bccrew
While I'm aware that DAB+ is supported in the Just Radio application, it would be nice to also implement support for the RTL283x tuners that can handle DAB.
I'm not sure if this implementation is possible but at the moment, no backend is supporting this and it would be a nice surplus!
Thanks for the feedback!
Link to post
There are no plans to support DAB. Since DVBViewer supports internet radio in the channel list DAB wouldn't yield much surplus anymore. Rather surminus, comparatively :)
Link to post
hackbart
If you need DAB(+) you might check JustRadio. The windows version comes with DAB(+) support.
Link to post
Thanks hackbart, I was just hoping to be able to schedule recordings through the same slick webinterface as the DMS ;)
Just Radio is working great.
Link to post
