Rob66 Posted February 4, 2018 Share Posted February 4, 2018 (edited) Using DVBViewer 6.0.4.0 Satellite card TBS6928SE Rotor Stab Rotor HH100 Satellite Eutelsat 9E, Hotbird 13E, Astra 19.2E\23.5E\28.2E DiSEqC command sequence: see attachment My problem: I point my rotor from Astra 28.2E (BBC London) to Eutelsat 9E (BBC World). The positionering (disk rotation) take approx. 30 sec... Resulting DVBViewer is NOT synchronizing with the (BBC world). Signal level is 95% but still waiting for synchronization (Black screen). When I activate an other canal on Eutelsat then Receiving is ok. When I return to BBC world the then Receiving is ok to.. Look to me that DVBViewer have problems to Synchronic after 30 sec of rotation. When I adjust my internal delay to 30 sec then it will be synchronize. But for each sat change I have to wait 30 sec..... I like to take out the internal time delay of 6000 msec But then I have always synchronisatie problems.. QST 01 Is there an option in DVBViewer that the synchronization will work all the time? 02 Is my Stab rotor H110 the problem... Hope that some one can help my out this synchronization problem Thx Rob, The Netherlands PS The last picture Astra 19.2 is an example Edited February 4, 2018 by Rob66 Layout Quote Link to comment
Griga Posted February 6, 2018 Share Posted February 6, 2018 On 4.2.2018 at 11:39 AM, Rob66 said: Signal level is 95% but still waiting for synchronization (Black screen). When I activate an other canal on Eutelsat then Receiving is ok. What does the DVBViewer Filter property page show when there is a black screen? http://www.dvbviewer.com/griga/DVBSource E/DVBSource.html#PropertyPage Quote Link to comment
Rob66 Posted February 6, 2018 Author Share Posted February 6, 2018 (edited) Thxs for your answer, See attachment I activate MPEG2 In Depth format detection Now it I get audio NOT video (from time to time a little bit Audio and Video) When I activate an other canal (same satellite) then the video audio is ok.When I return to the last station (same satellite) then the video audio is ok to. It look likes it is an little bit beter... Rob, The Netherlands Edited February 6, 2018 by Rob66 Quote Link to comment
Griga Posted February 6, 2018 Share Posted February 6, 2018 21 minutes ago, Rob66 said: When I activate an other canal (same satellite) then the video audio is ok. Does it make the motor move again, maybe only a little bit? The screenshot looks like the stream is not received properly (like bad reception, dish not aligned correctly), because there are a lot of discontinuities, preventing the DVB Source from detecting the video format (thus displaying ???). Usable audio data is not received at all. Or does it change after some time? Quote Link to comment
Rob66 Posted February 6, 2018 Author Share Posted February 6, 2018 56 minutes ago, Rob66 said: Does it make the motor move again, maybe only a little bit? Don't move. When I select an other channel the Video/Audio is coming up direct no daley.. I check te alignment of my disk by using a small Control box, see attachment Result it is perfect in line to the max level of 95% I get on the exact pos of my disk >Usable audio data is not received at all. Or does it change after some time? NO from time to time I get a small bloep of video audio, see attachment Rob, The Netherlands Quote Link to comment
Griga Posted February 6, 2018 Share Posted February 6, 2018 Is the number of discontinuities continuously increasing in the "bad" state? Quote Link to comment
Rob66 Posted February 6, 2018 Author Share Posted February 6, 2018 6 minutes ago, Griga said: Is the number of discontinuities continuously increasing in the "bad" state? All te time the same.... until I go to other channel at the same satellite.. Quote Link to comment
Griga Posted February 6, 2018 Share Posted February 6, 2018 If the discontinuities get more and more, DVBViewer receives a broken stream. Maybe the DVB device or its driver get somehow "out of tune" while the motor is moving, and it takes a retune to fix it. If I'm right switching to another channel on the same frequency/transponder will not fix it. Can you confirm this? Quote Link to comment
Rob66 Posted February 6, 2018 Author Share Posted February 6, 2018 53 minutes ago, Griga said: If I'm right switching to another channel on the same frequency/transponder will not fix it. Can you confirm this? NOT Confirmed. Switching to another channel on the same frequency/transponder will fix the problem. Quote Link to comment
