mezzy Posted March 18, 2019 Posted March 18, 2019 Hi is there a way to get EPG from DMS 2.1.4 in xml file to export it from webinterface thanks for reply Quote
Griga Posted March 18, 2019 Posted March 18, 2019 You can get it e.g. on the server PC by entering http://127.0.0.1:8089/api/epg.html?... in your browser (provided the web server port is still 8089 in your setup). There are several options that can be added as parameters after the ?. They are specified in the wiki. You may also want to search the API change log for "epg.html" in order to find more up-to-date information. Please note that your browser may crash if it has to render several MB of XML EPG data for displaying it. You can avoid it by adding the parameter &download=1 to the query part of the URL. It lets the browser download the XML data as file instead of displaying it. In the next release the DMS will also support XMLTV compliant output besides its own proprietary XML format. Here is the appropriate section of the forum for asking questions about the DMS API. Quote
