Nayef Posted September 1, 2024 Posted September 1, 2024 (edited) Hi i have mix guide from WebGrab+ & epg from tuner i note some epg info Show in page: http://192.168.100.2:8089/tvguide.html?aktion=tvguide but not Show in my client iptv player & also page: http://192.168.100.2:8089/epg_listnew.html?aktion=epg_listnew my setting: m3u: http://user:pass@192.168.100.2:8089/channels.m3u?tags=124 xmltv: http://user:pass@192.168.100.2:8089/api/epg.html?lvl=2&xmltv=1&favonly=1&xgrab= any idea? Edited September 1, 2024 by Nayef Quote
Griga Posted September 1, 2024 Posted September 1, 2024 vor 12 Stunden schrieb Nayef: i have mix guide from WebGrab+ & epg from tuner Please note: Though the Media Server stores both EPG types, it either uses the DVB EPG (from tuner) or the external (imported) EPG for a channel, but never a mix of both! Which EPG type shall be used in DVBViewer and the web interface (not for XMLTV export) can be configured in the DVBViewer Channel Editor on the server PC per channel by using the "EPG" button on the right, or after selection of a category for all contained channels by using the "Displayed EPG Types" checkboxes: You can ignore MHW EPG (Media Highway), because is not relevant for you. If both DVB EPG and External EPG are checked, DVBViewer and DMS prefer External EPG over DVB EPG for the channel. They only use the DVB EPG if no external EPG is available for a channel. If only DVB EPG is checked, DVBViewer and DMS will use the DVB EPG (from tuner) for the channel, but no External EPG. If there is no DVB EPG for the channel, no EPG is displayed for the channel at all. If only External EPG is checked, the same applies accordingly. Please note that the DMS does not use changed channel settings, until they have been saved in the DVBViewer Channel Editor on the server PC. It may also be necessary to reload the web interface page for displaying the change. vor 12 Stunden schrieb Nayef: i note some epg info Show in page: http://192.168.100.2:8089/tvguide.html?aktion=tvguide but not Show in page: http://192.168.100.2:8089/epg_listnew.html?aktion=epg_listnew Both pages should display the same EPG information for the same channel (!), because both are using the same method for getting EPG data. I can see no difference in the code for the TV Guide and the Channel EPG page. There is only one possibility I can think of: The EPG information could be different, if you have duplicates in your channel list (with other words, the same channel two times with different channel data and/or EPG configuration), and the TV Guide displays the EPG for one of them and the Channel EPG page the EPG for the other one. Please check it. vor 12 Stunden schrieb Nayef: but not Show in my client iptv player: xmltv: http://user:pass@192.168.100.2:8089/api/epg.html?lvl=2&xmltv=1&favonly=1&xgrab= You can exclude an EPG type from the XMLTV export by additionally using the source parameter (see here). Adding ...&xgrab=&source=1 to the URL excludes the DVB EPG, so only the external EPG is used for all channels, and ...&xgrab=&source=4 excludes the external EPG, so only the DVB EPG is used for all channels. Without source parameter no EPG type is excluded, but the external EPG is preferred over the DVB EPG, if both types are available. In this way you cant try which setting lets the missing EPG information show up. Please note that your IPTV player must reload the EPG for the change to take effect. 1 Quote
Nayef Posted September 3, 2024 Author Posted September 3, 2024 (edited) Thanks for all this info! Edited September 3, 2024 by Griga Removed unnecessary quoting Quote
