makinjr Posted January 27, 2006 Posted January 27, 2006 I have been using DVBViewer now for while and must say I am very pleased! I even got subtitles working somehow with YLE with little work One minor detail is missing. My hauppauge Nova-T USB 2 remote control won't work. I would like to have it working. I search through forums to find out how, but did not succeed. If anyone knows how it is possible with current version, please let me and others know. Or is there anywhere available detailed information how remote control operates? Perhaps I could create my own plugin or something to do the trick... Just need to to know what to do? Does Hauppauge provide that information somewhere? I can not find it. Thanks in advance! Quote
makinjr Posted February 2, 2006 Author Posted February 2, 2006 I managed find answer myself and now want to share it with you. With hauppauge you get installed infrared software ir.exe. You can use that with DVBViewer. Found file "C:\Windows\irremote.ini" and open it with notepad. 1) Add single line to [Applications] section. Line should look like this: DVBViewer= 2) ind [Default] section and edit it to look like this: (note that you must set PATH environment variable to include your DVBViewer path). [Default] OLD0= 0= 1= 2= 3= 4= 5= 6= 7= 8= 9= TV={close(radio.exe)}{sleep(750)}{run(DVBViewer.exe)} TVNEW={close(radio.exe)}{sleep(750)}{run(DVBViewer.exe)} SOURCE={switch(*task*)}{shift}{tab} MINIMIZE= FULLSCREEN={alt}{space}x RESERVED= 3) Add section [DVBViewer] somewhere. Here is a sample. I have edited only those parts I would need and have information. [DVBViewer] OLD0=0 0=0 1=1 2=2 3=3 4=4 5=5 6=6 7=7 8=8 9=9 NAVLEFT={LEFT} NAVRIGHT={RIGHT} NAVUP={UP} NAVDOWN={DOWN} OK={enter} BACK={esc} ;BACK={BACK} ; old remote, not supportted SOURCE= MINIMIZE= FULLSCREEN={alt}v{alt}f RESERVED= GRNPOWER={sys(0xF060)} GO={alt}{home} MENU={alt}D ;;mappings to use APPCOMMANDS MUTE={app(0x80000)} CHNLUP={UP} CHNLDOWN={DOWN} VOLUP={RIGHT} VOLDOWN={LEFT} REC=R STOP=R ; ; THESE ARE UNEDIT, FEATURE NOT FOUND IN DVBViewer PAUSE={app(0x2f0000)} PLAY={app(0x2e0000)} REWIND={app(0x320000)} FASTFWD={app(0x310000)} SKIPFWD={app(0xb0000)} SKIPREV={app(0xc0000)} ;Teletext Group, Not yet edited RED={ctrl}z GREEN={ctrl}q YELLOW={ctrl}x BLUE={ctrl}c TEXT=v ; try pushing both CC and Subtitle, hopefully one is valid SUBCC={alt}v{alt}o TV=f TVNEW=f RADIO={ctrl}a MUSIC={ctrl}m VIDEOS={ctrl}e PICTURES={ctrl}i GUIDE=E CHNLPREV={ctrl}l 4) Save file and restart ir.exe. Now ir.exe should control DVBViewer remotelly. Good luck! Quote
cocksy_boy Posted February 16, 2006 Posted February 16, 2006 Hi there Makinjr, cheers for the details - just a quick question - which remote control do you have? I'm very new to all this and am trying to figure out which button is called what in the ini file. The reason I ask is that I have a 45 button silver remote that came with my nova-t pci, but I'm not sure that this corresponds to your ini file. The notes in the ini file in my system folder don't make a lot of sense to me - I'm trying to decipher them at the moment! Cheers for any help, Cocksy. Quote
makinjr Posted February 27, 2006 Author Posted February 27, 2006 I have 45 button remote Hi there Makinjr, cheers for the details - just a quick question - which remote control do you have? I'm very new to all this and am trying to figure out which button is called what in the ini file. The reason I ask is that I have a 45 button silver remote that came with my nova-t pci, but I'm not sure that this corresponds to your ini file. The notes in the ini file in my system folder don't make a lot of sense to me - I'm trying to decipher them at the moment! Cheers for any help, Cocksy. <{POST_SNAPBACK}> Quote
