ardua97 Posted January 22, 2008 Posted January 22, 2008 excuse me for my english Hello I have a HTPC with Windows vista Home Premium and i have a hauppauge HVR 4000 Initially I'm not able to make work the double LNB (Hotbird-Astra) so i try toio buy a used skystar 2 and it work with the double LNB ( in the same time i changed also the Double LNB) and i use DVBViewer to see tv , i use the hauppauge for the DVB-T channel and the Skystar 2 for the DVB-S channel but with the skystar i have a problem , when i restart after standby (s3) the pc the DVB-S channel do not work , so i try to connect the dish to hauppauge and the standby problem is solved but in this configuration (dvb-t connect to hauppauge , dvb-s connect to hauppauge) i have a new problem in DVBViewer i hame my favorite list with dvb-s and dvb-t channel mixed in a single list when i start DVBViewer it bagin with a dvb-t channel and it work correctly so i change channel , when i arrive to a dvb-s channel i have to wait some time but the the dvb-s channel work correctly but after that the dvb-t channel do not work any more after a dvb-s channel is sintonized the dvb-t channel do not work have you some suggestion to me Quote
mabruk Posted January 22, 2008 Posted January 22, 2008 (edited) excuse me for my english Hello I have a HTPC with Windows vista Home Premium and i have a hauppauge HVR 4000 Initially I'm not able to make work the double LNB (Hotbird-Astra) so i try toio buy a used skystar 2 and it work with the double LNB ( in the same time i changed also the Double LNB) and i use DVBViewer to see tv , i use the hauppauge for the DVB-T channel and the Skystar 2 for the DVB-S channel but with the skystar i have a problem , when i restart after standby (s3) the pc the DVB-S channel do not work , so i try to connect the dish to hauppauge and the standby problem is solved but in this configuration (dvb-t connect to hauppauge , dvb-s connect to hauppauge) i have a new problem in DVBViewer i hame my favorite list with dvb-s and dvb-t channel mixed in a single list when i start DVBViewer it bagin with a dvb-t channel and it work correctly so i change channel , when i arrive to a dvb-s channel i have to wait some time but the the dvb-s channel work correctly but after that the dvb-t channel do not work any more after a dvb-s channel is sintonized the dvb-t channel do not work have you some suggestion to me Hello ardua, For the first problem you have to go to device manager, find properties for the ss2 - in network adapters - then energy administration and untick the feature to stop the device in order to save energy. And for the second, go to DVBViewer settings>options>hardware and tick "stop stream while tunning" on both Terrestrial and Satellite. Cheers from sunny Spain Edited January 22, 2008 by mabruk Quote
ardua97 Posted January 24, 2008 Author Posted January 24, 2008 Hello ardua, For the first problem you have to go to device manager, find properties for the ss2 - in network adapters - then energy administration and untick the feature to stop the device in order to save energy. And for the second, go to DVBViewer settings>options>hardware and tick "stop stream while tunning" on both Terrestrial and Satellite. Cheers from sunny Spain thank you very very very very very very very very much the solutions worked both correctly i think that i'll continue to use the Hauppauge for DVB-T and Skystar 2 for DVB-S because connecting the dish to hauppauge (and so using only hauppauge for dvb-s and dv-t) channging channel trom dvb-t to dvb-s is very slower but the solution are very very very very usefull thanks so much Quote
