thl Posted November 3, 2008 Posted November 3, 2008 Can someone tell me how to use the Timer information in the DVBViewer to get the Scheduler.exe to wake up the PC from hibernate on Windows Vista and start recording ? It works if the PC is on (not Standby or Hibernate). SETUP INFORMATION: In the DVBViewer - (settings-Options-Extended) Task Scheduler Support: - Checked "Use Microsoft Task Scheduler" - Execute as "PC-NAME\username" and password In the "DVB Task Scheduler v.2.2.3.0" i have checked Settings: - When DVBViewer Closes - On Staby/Hibernate -> Continue With Hibernate. - Restart DVBViewer Without Tuning Last Channel - 3 Minuts Lead Time Settings 2: - 0: Restart on Resume - 0: Time to wait in Milisec The DVBViewer.log gives errors like this: 19.10.2008 09:02:31 Scheduler Error 8007052E - pIPersistFile.Save() failed TV-card: Hauppauge WinTV-HVR-1700 a support.zip is attached. Regards Thomas support.zip Quote
Hartwig Posted November 7, 2008 Posted November 7, 2008 The reason can be an empty or a wrong password. Quote
thl Posted November 9, 2008 Author Posted November 9, 2008 The reason can be an empty or a wrong password. You were quite right. . . . A simple answer to a very annoying problem, many, many thanks. best regards Thomas Quote
