HOWTO: Handle DVBViewer Events with AutoIT
dbraner
Hi guys,
after a long time of (unsuccessful) attempts handling DVBViewer COM events in C++ and Visual Basic Script I figured out how to catch events using AutoIT scripting. ;)
Here's an example:
; Eventhandler for onAction
Func Event_onAction ($ActionId)
  MsgBox (0, "Event", "onAction")
EndFunc
; Get running DVBViewer instance
$DVBViewer = ObjGet ("", "DVBViewerServer.DVBViewer")
If $DVBViewer = 0 Then
  MsgBox (1, "DVBVCommand", "DVBViewer not running")
  Exit
EndIf
; Install the event handler
ObjEvent ($DVBViewer.Events, "Event_", "IDVBViewerEvents")
If @error = 0 Then
; This is an endless loop. Maybe there's a better solution for waiting for events
  While (1)
  Sleep (500)
  WEnd
Else
  MsgBox (0, "Error", "Error = " & @error)
EndIf
The possible events are documented in the COM interface help file. Simply add your eventhandler functions to the code, i.e. onPlaystateChange.
Unfortunately my C++ code is still not working ... :D
Edited by dbraner
Danke :D
edit \ sehr cool OnPlaystatechange wird aufgerufen wenn die wiedergabe einer mediendatei beendet wird.
damit sollte sich doch was basteln lassen um die schwarzen bildschirme nach der dateiwiedergabe zu verhindern.
hast du schon rausgefunden wie man die verschiedenen parameter in der eventfunktionen verwenden kann?
edit2 \ achso ganz leicht: einfach den paramter in der msgbox abfragen! sehr cool
Edited by nuts
On more example for handling OnPlaystateChange event. The following code catches an OnPlaystateChange event and stores the new playstate in a datamanager property. Now it's easy to access this datamanager property from within your command.vbs script. You will always have the current playstate.
Dim $DVBViewer
Func Event_onPlaystateChange ($RenderType, $State)
  $DVBViewer.Datamanager.Value ("#EventCurrentRenderType") = $RenderType
  $DVBViewer.Datamanager.Value ("#EventCurrentPlayState") = $State
EndFunc
  Exit
EndIf
If @error = 0 Then
  While (1)
  Sleep (500)
  WEnd
Else
EndIf
This is only a workaround. A better solution is that Lars is setting this property in his code directly.
For possible render types and playstates see COM helpfile. In your command.vbs you can access the new properties by using
Have fun!
Dirk
Edited by dbraner
