Tjod Posted May 8, 2009 Posted May 8, 2009 1.) You need a DVBViewer 4.1.1 (or newer) installation [For all Users (usermode=2)]. Please check that you receive alle channels. 2.) Then install the Recording Service 1.5 RC2 (or newer) 3.) Activate in the Recording Service options the DVBServer http://en.DVBViewer.tv/wiki/Service_Configuration_Program http://en.DVBViewer.tv/wiki/Options_Service_-_DVBServer 4.) Look in ...\DVBViewer\Plugins if there is a svcctrl.dll, delete it 5.) Start the DVBViewer and go to Options > Hardware and set all TV cards to "don't use" 6.) Click on the + on this page and add for each card a unicast device. Set them all to normal and select the same tunertype as the real TV cards are (DVB-T,DVB-S ....). If the orginal card has a CI or is a DVB-S2 card set this for the unicast device as well. Then open the settings and select the DVBServer in the device options. http://en.DVBViewer.tv/wiki/Unicast_Network_Device 7.) Activate in the DVBViewer > Options > Recording Service the recording service support http://en.DVBViewer.tv/wiki/Options_Recording_Service 8.) Enter the data for the Recording Service Webinterface and check with the Test button if they are correct http://en.DVBViewer.tv/wiki/Unicast_Network_Device 9.) Select the things you like to get in the DVBViewer from the recording service. http://en.DVBViewer.tv/wiki/Options_Recording_Service http://en.DVBViewer.tv/wiki/Category:DVBVi...cording_Service
