Technisat Skystar S2 - Dead after standby
Andrey123456
Technisat Skystar S2 does not support standby mode. Tested with driver 4.5.0
After wakeup reset required or... installing DVBViewer Recording Service 1.5.0.31 Beta together with BDA drivers partially solves the problem.
The driver is the same for all B2C2 cards, so what about others? I tested only Skystar S2.
If standby mode is important for you, think twice before using this card. Unless comprehensive solution will come soon or driver bug will be fixed.
