Technomannz Posted February 20, 2010 Posted February 20, 2010 I;ve been using DVBViewer for a year or so now, and I've found that the files recorded using DVBViewer can also be played on VLC Mediaplayer. I recently downloaded and started using the DVBViewer recording service (1.5.0.31). The service works fine but any video recorded using the recording service can only be played on DVBViewer, VLC Mediaplayer can't play it. Both programs save the file in ts format. I've also tried the .mpg format - same result. Does anyone have a solution. Have I missed setting something? Technomannz Quote
Lars_MQ Posted February 20, 2010 Posted February 20, 2010 VLC Mediaplayer can't play it. Because VLC has a long running bug. Disable the autoload of subtitles in VLC and it will work. Quote
kdk_warhead Posted April 2, 2010 Posted April 2, 2010 I have the same problem but i cant find the setting you are talking about I'm using VLC 1.0.5 Quote
Tjod Posted April 2, 2010 Posted April 2, 2010 Change Show settings to All. Video > Subtitles > Quote
Mr. Man-wai Chang Posted September 18, 2011 Posted September 18, 2011 Is it absolutely sure that it's the fault of VLC Media Player, not DVBViewer Pro? Has things been improved now? Quote
Tjod Posted September 18, 2011 Posted September 18, 2011 Is it absolutely sure that it's the fault of VLC Media Player, not DVBViewer Pro?Yes Has things been improved now?It was Fix in one VLC Player Version but reappeared in the next version.http://trac.videolan.org/vlc/ticket/3547 So the solution is to disable "Autodetect subtitle files" in VLC player. Quote
RedDwarf Posted October 29, 2011 Posted October 29, 2011 (edited) For a better solution: Dump VLC and get yourself a better mediaplayer. It was always a POS. I have never understood why people use it. I tried it and quickly moved on. Edited October 29, 2011 by RedDwarf Quote
