Solarfox Posted June 29, 2010 Posted June 29, 2010 (edited) Hi I just bought brand new unpacked SkyStar HD2 from shell in MediaMarkt and installed card etc, even open a channel what was last time watched, but when i want to open some other channel sat card act strange and mouse got hourglass for few second and no signal anymore. Than i pull out card, installed on another slot, same crap... Pull out card, install in another PC and same... Than i pull out card out and look on her and found that one resistor is not solder on place so i need someone who can make nice picture of that part what is in circle, on this image is what should be, it`s image from internet and my resistor is soldered "HORIZONTAL" not vertical like is on cards what i found on internet. Problem is that i`m at home now, 1300 km from Mediamarkt where i bought this card so i don`t think so i can go back and return that card so easy for replacement Maybe a problem is only that one resistor, so i will use hotair solder and tweezers than fix that but i want better picture to see better. Thanx in advance... Edited June 29, 2010 by Solarfox Quote
Solarfox Posted June 30, 2010 Author Posted June 30, 2010 http://www.muizenshop.nl/layout/media/32001-32200/32103_1_image.jpg There is a Terratec same card, a much better in quality. Now i see that first from left side is 342 and second one is 0 on mine first is 0 and second is 342 third missing I have a whole bunch of old mobile phones, so i can use parts from them, just need a value for that small 3rd from left. Quote
Gioxy Posted June 30, 2010 Posted June 30, 2010 IMO you better contact directly TechniSat company, maybe there's a hidden (for us) reason for this difference... anyhow I think they can lead you stright to the solution (or maybe they can be so kind to quickly replace your card... you're not at North Pole now, isn't it? ) Quote
