fooladi Posted June 25, 2011 Posted June 25, 2011 (edited) SVP is freeware that allows you to watch any video on your PC file with frame interpolation (like you can watch it on high-end TVs and projectors). It increases frame rate by generating intermediate animation frames between existing ones to produce very smooth, fluid and clear motion. The technology is well-known for a while ("TrimensionDNM", "Motion Plus", "Motionflow" and others), but now it's available for free to PC users with simple GUI and just a couple of mouse clicks. Since version 3.0 SVP provides GPU acceleration and now it's possible to watch FullHD 1080p-video recalculated to 60Hz in real-time on any modern GPU hardware. SVP actually is not a video player itself, but it enables almost any player to play smooth video. http://www.svp-team.com/wiki/Main_Page In DVBVewer pro you can select ffdshow as decoder or use " Video postprocessor Plugin" and choose ffdshow as video postprocessor. SVP by Auto selecting and activating Avisynth scripts increase framrate by calculating and processing motion in video. notes: when using SVP you must select "resize & aspect" in ffdshow Always because switching between different video size channels or different aspect Ratio may cause dvbveiwer to crash! (DVBViewer pro 4.5) dont select " keep original aspect ratio" and "Process Aspect ratio internally" sometimes you need to select Manual Aspect Ratio and overlay aspect ratio. if CPU usage is too high, dabble click on svp in system tray and configure profile. for example for smooth improvement select: by blocks --------------------------------------------------------------------------------------------------------------- Can not pay for DVBViewer Pro because UN Sanction on my country Edited June 25, 2011 by fooladi Quote
fooladi Posted June 26, 2011 Author Posted June 26, 2011 SVP use ffdshow for produce smooth 60FPS playback. for enabling ffdshow as decoder in DVBViewer you must configure ffdshow video decoder as following image: Quote
fooladi Posted June 26, 2011 Author Posted June 26, 2011 (edited) You Can use your own decoder in DVBViewer but add "ffdshow raw video filter" as PostProcessor for this edit video PostProcessor plugin setting: Help > Configuration folder > Plugins > PostProcessor.ini edit: [setup] PostProcessor=ffdshow raw video filter [Postprocessors] CLSID.0={0B390488-D80F-4A68-8408-48DC199F0E97} Name.0=ffdshow raw video filter CLSID.1={0524CEA7-7E7D-4804-8A7B-D17A99807D3C} Name.1=NVidia Post Processor CLSID.2={3BAFDCB6-8CF6-4D08-9FCE-2D2883A9FB32} Name.2=Creeo Post Processor CLSID.3={F9BA22CA-0704-45EE-A8F9-AC246411A6FA} Name.3=MoMoLight CLSID.4={04FE9017-F873-410E-871E-AB91661A4EF7} Name.4=ffdshow Video Decoder [ExcludeDecoders] //CyberLink H.264/AVC 0={F141C519-48A6-4B92-8053-AFEE27D5D069} //CyberLink H.264/AVC (PDVD7) 1={D12E285B-3B29-4416-BA8E-79BD81D193CC} //CoreAVC 2={09571A4B-F1FE-4C60-9760-DE6D310C7C31} //MainConcept AVC/H.264 3={6A270473-9994-4AEB-801F-BB2C4E56EE38} restart DVBViewer and select ffdshow raw video filter in video PostProcessor plugin note: if Yo have problem with colors(blue > yellow) enable postprocessing in ffdshow raw video filter. I prefer this method so for my ATI Graphic card I can use Cyberlink video decoder (HAM) and ffdshow raw video filter as PostProcessor ( SVP use this for increase frame rate) and EVR Custom for Renderer Edited June 26, 2011 by fooladi Quote
majstang Posted June 26, 2011 Posted June 26, 2011 Although its kind of cool with these rendering scripts enabling you to accomplish smoother picture without ghosting and such, but the Interpolation technology is awful in its essence. Mainly due to the "Soap opera effect" making all video unwatchable, in my point of view. If you do find scripts abled to apply black frame insertion (bfi), it would be quite an another deal. In such a case let me know. Here is some info on what im talking about: http://www.xbitlabs.com/articles/monitors/display/lcd-parameters_4.html Quote
fooladi Posted June 26, 2011 Author Posted June 26, 2011 thanks for your idea note that in modern TVs this effect persist yet. by changing settings you can reduce this annoying effect at the expense of high CPU and GPU usage. for me with ordinary LCD, Interpolation technology of SVP make watching comforter I hope 25-30 FPS standards change someday and increase in cameras and broadcasting! sorry for my bad English Quote
fooladi Posted July 1, 2011 Author Posted July 1, 2011 I found that if we disable fast channel switching then no need to resize video by ffdshow. (Settings -> TV+Radio -> Fast Channel Switching). Please tell us about your experience using SVP. Quote
kasper17 Posted July 9, 2011 Posted July 9, 2011 This Is the most Extraordinary Thing I've never seen... Espacially with "MainConcept MPEG-2 Video Decoder" !! Everyone Should give It a try..."awesome" Quote
galmok Posted July 21, 2011 Posted July 21, 2011 I tried to make it work, but got very low and unstable framerates as a result. If I turn _off_ OpenCL (ATI 5870 hardware), it runs smooth, though. Quote
fooladi Posted July 21, 2011 Author Posted July 21, 2011 I tried to make it work, but got very low and unstable framerates as a result. If I turn _off_ OpenCL (ATI 5870 hardware), it runs smooth, though. install latest AMD Driver+OCL to solve this. Quote
voice Posted January 20, 2013 Posted January 20, 2013 Good day! DVBViewer 5.0 when using SVP 3.1.3 (http://www.svp-team.com/)switching satellite channels often terminates with an error: Description: Error led to a halt cooperation program with Windows. Problem signature: Problem Event Name: AppHangB1 Application Name: DVBViewer.exe Application Version: 5.0.0.0 Application Timestamp: 2a425e19 Signature hangs: af11 Type hovering 513 OS Version: 6.1.7601.2.1.0.256.1 Language code: 1049 Extras. hang signature 1: af1154a4464b8c03b4e130fe2469d0ce Extras. hang signature 2: 46db Extras. hang signature 3: 46dbe025066b8398e46b2f578d9c64e8 Extras. hang signature 4: af11 Extras. hang signature 5: af1154a4464b8c03b4e130fe2469d0ce Extras. hang signature 6: 46db Extras. signature hangs 7: 46dbe025066b8398e46b2f578d9c64e Any options for changing settings or SVP decoder / renderer does not change anything. Additional Information: Windows x64 FFDSHOW core i7 3770 Gainward gtx 560 ti 8GB Sound Blaster X-Fi Titanium Fatal1ty Professional Series SSD Vertex 4 TT-budget S2-3200 thanks in advance! support.zip Quote
