entrecour Posted March 14, 2012 Posted March 14, 2012 Sometimes when I start DVBViewer 4.9.5 I get a script control message and DVBViewer will not start. I have also had one BSOD. I couldn't see anything relevant in the logs. Quote
majstang Posted March 20, 2012 Posted March 20, 2012 I have seen the script control message as well the first two times when starting newly installed DVBV 4.9.5. It flashed by in a second and was closed automatically. Havent seen it since. For me DVBV started alright though and no BSODs. With DVBV 4.9.5.1 havent seen the message. Quote
entrecour Posted March 20, 2012 Author Posted March 20, 2012 I have had this problem 2-3 times since the initial startup after the 4.9.5 install. I haven't noticed any pattern except that may be its more likely to happen after a restart of the PC. The initial script delay after the install seemed very long at the time. Now when the script message appears again I just leave it and it goes away by itself. I now think the BSOD was caused when I tried to end the script instead of leaving it to continue. I don't have any scripts that are not part of the standard install, and I don't actively use any, but I do have several plugins (X, Online, MyMovies, NeutrinoCL, miniepgvars, myscrobbler) most of which are part of X-skin black glass - I wonder if they would be subject to the script message also? Quote
majstang Posted March 20, 2012 Posted March 20, 2012 I just noticed in the german section that Lars may have found the problem: http://www.DVBViewer.tv/forum/topic/48843-script-control-fehlermeldung/page__view__findpost__p__360119 Quote
