Imbalanced Zero Posted June 17, 2012 Posted June 17, 2012 If you have a Passive 3D TV or Monitor, this shader should be useful. It should allow you to watch Side-by-Side broadcasts without you needing to switch to 3D Mode. And the best thing is you get to keep your EPG intact. It will only work in full-screen, not entirely sure how you make it work when it's windowed, but maybe someone else will figure that one out. <?xml version="1.0" encoding="iso-8859-1"?> <Shader> <Profile>ps_2_0</Profile> <Description>Side By Side to Line-Interlace</Description> <Code> sampler s0 : register(s0); float4 p0 : register(c0); #define width (p0[0]) #define height (p0[1]) #define halfscreenheight height/2 float4 main(float2 tex : TEXCOORD0) : COLOR { tex.x = tex.x*0.5; float4 l =tex2D(s0, float2(tex.x,tex.y)); tex.x = tex.x + 0.5; float4 r =tex2D(s0, float2(tex.x,tex.y)); float grid = frac(tex.y*halfscreenheight); if (grid>0.5) { return l; } else { return r; } }</Code> </Shader> SBS.xml Quote
unklez Posted July 22, 2012 Posted July 22, 2012 (edited) Would this work with DLP projectors? Think I need checkerboard mode instead of interlace for DLP Edited July 22, 2012 by unklez Quote
