HbbTV
hackbart
DVBViewer HbbTV Plugin
After almost two years of work we finally finished the HbbTV integration in the DVBViewer. The project was developed in cooperation with a
Team around Prof. Jäger from the FH Friedberg.
What is this all about?
Hybrid Broadcast Broadband TV or “HbbTV”, is a major new pan-European initiative aimed at harmonising
the broadcast and broadband delivery of entertainment to the end consumer through connected TVs and set-top boxes.
(http://www.hbbtv.org/)
In short terms it is a combination to deliver additional content from broadcasters to the customer via Internet.
This Video gives you a short demonstration how you can interact with your DVBViewer/TV by using this system.
http://youtu.be/3ccAEQt6ii4
Many european broadcasters started to use this system in the last two years and a lot others will follow.
Since CE-HTML is an important subset of HbbTV the DVBViewer is also capable to play additional CE-HTML based content:
How can I get it?
If you own the DVBViewer you can grab a license within the keytool, or by using this ordering website:
  • Like 1
