hackbart Posted September 13, 2013 Posted September 13, 2013 We have released the new DVBViewer Pro 5.2.8 today. ATTENTION: You can download the DVBViewer Pro 5.2.8 only from https://www.DVBViewer.tv/members/ We introduced in 2010 a new protection system with Version 4.5, if you haven't already got the new user credentials please read also: http://www.DVBViewer...ew-credentials/ Mit der Version 4.5 wurde 2010 ein neues Benutzerdatensystem eingeführt, wer die neuen Daten noch nicht hat bitte unbedingt hier lesen: http://www.DVBViewer...-benutzerdaten/ DVBViewer Pro 5.2.8 In Memoriam - Lars Gehre Changelog General Change: TS Playback: The package size is now detected more accurate Fix: COM: The Interface IHbbTV is now located under the DVBViewer3 Interface Fix: Vod Source: Obviously wrong HbbTV-urls are not repaired Change: COM-Interface: HbbTV Interface is now moved to a new IDVBViewer3 Interface Add: COM-Interface: new OSD2 interface with Showpopup2 function Change: TS Playback with DVBSource: The TS packet size is now detected automatically. Previously DVBViewer only relied on the file extension (.ts, .m2ts). Fix: TS Playback with DVBSource: Under certain (rare) circumstances video wasn't detected in TS files. Change: File/Stream Playback without DVBSource: Enhanced aspect ratio detection, particularly on-the-fly changes (depending on the video decoder). Fix: Stream Playback: A splitter name specified in a filtergraph preset wasn't assigned to the splitter and didn't show up under View -> Filters Add: File/Stream Playback: Presets are now shown under View -> Filters Add: Scanner: Widestring support in channel scan, same like in the GE Fix: Playback: support for <=L2000 WMV DRM via wmvdrm.dll: __stdcall HRESULT WMCreateCompanyCertificate(IUnknown **pUnkCert; GUID *Company); Fix: VodSource: Test für Content-Range if the server does not return the proper file size (e.g. DR dk) Change: General code cleanup Add: Options: Channel Logo editor under options Change: Options: Former "Is DVB-S2 device" checkbox replaced by a DVB-S2 / DVB-T2 checkbox that is now located above the tuner type dropdown list. Add: Channel Editor: DVB-T2 checkbox, Substream ID checkbox and Substream ID input field for DVB-T/T2 channels. Please note: Channels that are flagged as DVB-T2 require a tuner that is flagged as DVB-T2 capable Hardware Change: DVBSky: Disabled PMT Polling if no CAM is available Add: Terratec H7/S7: Support for CAM and DiSEqC Add: Started implementing the DVB-T2 support Fix: Source IP only partly checked on IPTV transponder comparison EPGFix: fix for problems with diacritic char sets HbbTV Fix: HbbTV: The automatic translation is disabled for the browser list Fix: HbbTV: Some providers send wrong URIs for their videos, they are now repaired before playback starts Fix: HbbTV: ACTION_DVD_MENU does not open HbbTV anymore Fix: HbbTV: The automatic translation is disabled for the browser list Fix: HbbTV: Some providers send wrong URIs for their videos, they are now repaired before playback starts Add: MHEG-5: new engine build which required changes in the interface Fix: HbbTV: partially rewrite of the html loader, if an application/ce-html+xml or application/vnd.HbbTV.xhtml+xml is used. ZDF should run fine as well as Mediathek Fix: HbbTV: the window ignored the Close OSD on Video playback setting Fix: HbbTV: content is stored in the cache-subfolder Fix: HbbTV: https urls now also work fine if the MIME type application/vnd.HbbTV.xhtml+xml is used Fix: HbbTV: The window cleared a background while loading a video, which caused removed background textures on some skins Fix: HbbTV: created a dummy KeyEvent Object, used on several sites (e.g. LokalTV) Change: HbbTV: new HbbTV.xml file for configuration and auto update located under http://www.DVBViewer.tv/hbbtv.xml Fix: HbbTV: Debug Window did not worked, caused by the Popupblocker There are a couple of changes concerning the HbbTV/MHEG5 Plugins, so if you wonder what this is, you should have a look in here. 2
