MarkusK Posted January 10, 2014 Share Posted January 10, 2014 There are no permanent changes with this tweak and it can be uninstalled as every other tweak. It works fine on my device. Was only a suggestion Link to comment
7abib0 Posted April 22, 2014 Share Posted April 22, 2014 guys where is iOS_705 files you are talking about. I only found iOS_703 in this forum! Link to comment
MaxB Posted April 22, 2014 Share Posted April 22, 2014 iOS_703 and iOS_705 are outdated, you'll find the actual Version in the members section here. Link to comment
rumave Posted September 26, 2014 Share Posted September 26, 2014 Hi all, IOS8 Has te same issue... All years with a new software release for ios, webapp crash... Any idea for this?? Link to comment
lbjerring Posted October 5, 2014 Share Posted October 5, 2014 I also have issues with streaming to iPhone with IOS8. Streaming a recorded show works fine, but when streaming live TV it stop after 10-15 sec. Link to comment
helio58 Posted October 6, 2014 Share Posted October 6, 2014 I also have issues with live tv iPhone 6 plus ios8.02 Recorded streaming works, live streaming don't start just buffering , after same time just the play button with a mark over no play. Link to comment
rumave Posted October 6, 2014 Share Posted October 6, 2014 (edited) i have the same issue. In Other german post , are talking about this. But , at the moment don't exist solution ... i have iphone 6 with IOS 6.0.2 too. This program si the best streaming program but, don't works fine in IOS8 Edited October 6, 2014 by rumave Link to comment
rumave Posted October 12, 2014 Share Posted October 12, 2014 Hello, A possible idea for solve streaming issue. https://flowplayer.org/forum/#!/open_word:ios-8-upgrade Link to comment
denethor Posted October 12, 2014 Share Posted October 12, 2014 Today 1.30 released with huge release notes. But there was nothing about iOS. I'm tried it anyway of course. My iPhone4 with iOS 7 still working but my 3 other iPhones (iPhone 5,6,6+ with 8.02) all fails to streams both live TV and recorded ones Link to comment
hackbart Posted October 13, 2014 Share Posted October 13, 2014 It is not a problem of the Recordingservice at all. The issue is caused by Apple and their behaviour with live streams. Technically the recordingservice has to record live streams before they are provided by the web interface. The situation is and will be you select a channel, the service is converting the content on the fly starting after you select the stream and after a short delay the web site provides the stream to the quicktime video object embedded on the frame. The stream is just fine, but the timeout by quicktime causes your issue. You can change this by manipulating the values in the html template, but this will work only till apple decides to change the behaviour again. Link to comment
rumave Posted October 13, 2014 Share Posted October 13, 2014 Can you put an example to change this parameter? i'd like to play with html. Thanks 1 Link to comment
denethor Posted October 20, 2014 Share Posted October 20, 2014 Same with iOS 8.1. Just FYI Link to comment
MaxB Posted October 21, 2014 Share Posted October 21, 2014 (edited) Same with iOS 8.1. Just FYI No! iOS 8.1 and RS 1.30.1.0 are working with LiveTV by me, check it out, please! Edit: Sorry, iOS 8.1 is not working properly, using LiveTV is like playing lottery, but videos and recordings are working fine... Edited October 21, 2014 by MaxB Link to comment
denethor Posted October 21, 2014 Share Posted October 21, 2014 Same with iOS 8.1. Just FYI No! iOS 8.1 and RS 1.30.1.0 are working with LiveTV by me, check it out, please! I didn't notice that 1.30.1 has just released. Updated my server with hope but it failed. and yes I noticed the iOS8 section of release notes. There's a slight improvement with it though. I can now see the first frame but play button simply doesn't do anything. Can you please tell me more about your setup? Which iOS device (mine iPhone 6 and 6+) are you using, what is your stream settings?( aspect ratio, bitrate, encoder preset, buffer) Link to comment
Keyser Posted October 26, 2014 Author Share Posted October 26, 2014 It is not a problem of the Recordingservice at all. The issue is caused by Apple and their behaviour with live streams. Technically the recordingservice has to record live streams before they are provided by the web interface. The situation is and will be you select a channel, the service is converting the content on the fly starting after you select the stream and after a short delay the web site provides the stream to the quicktime video object embedded on the frame. The stream is just fine, but the timeout by quicktime causes your issue. You can change this by manipulating the values in the html template, but this will work only till apple decides to change the behaviour again. Hi Hackbart If that is the case, couldn't you work around that by changing the behaviour of the liveTV feature in the web interface? Example: When i press "stream", i get the second screen that allows me to select quality. Once i selected that couldn't you change what happens when I press start stream? Instead of opening the stream page right away, couldn't you start recording on the server but display a temporary page with a countdown to when it will redirect you to the actual viewing page? That way you could stall launching the quicktime object in my browser until you actually have recorded and buffered enough video on the server to be able to deliver the stream right away. -Keyser Link to comment
hackbart Posted October 26, 2014 Share Posted October 26, 2014 No, we did this for ios7 but in ios8 it is a bug which we can not "work around". You can use any other browser on IOS8 like Terra and you will see that it runs like intended: And terra does not even use anything else than the internal browser. PS: Feel free to add something like this in the html page, but i won't change the code just because Apple did something wrong. I'm sure they will fix this sooner or later since the video playback in general is awful. The Youtube App does not run fine, inside embedded video streams it is almost impossible to use the slider, except if you are in full screen mode etc. 1 Link to comment
denethor Posted October 26, 2014 Share Posted October 26, 2014 (edited) ...You can use any other browser on IOS8 like Terra and you will see that it runs like intended.. I do not know why I never tried other browsers before. This is kind a embarrassing for me. Now tried it with Chrome and it worked like a charm. Thanks for the tip. Edited October 26, 2014 by denethor Link to comment
helio58 Posted October 30, 2014 Share Posted October 30, 2014 I do not know why I never tried other browsers before. This is kind a embarrassing for me. Now tried it with Chrome and it worked like a charm. Thanks for the tip. I Have tried with Chrome , Dohlfin and Atom but it didn t work. Link to comment
Hansrh Posted November 10, 2014 Share Posted November 10, 2014 I can verify that the new iOS8-version works on my iPAD (iOS 8.1) with Opera web-browser. http://www.DVBViewer.tv/forum/index.php?app=core&module=attach§ion=attach&attach_id=38667 Link to comment
Marcos Martinez Posted January 10, 2015 Share Posted January 10, 2015 Why can't I find that iOS 8 version in the members area? te name="Hansrh" post="416973" timestamp="1415612003"] I can verify that the new iOS8-version works on my iPAD (iOS 8.1) with Opera web-browser. http://www.DVBViewer.tv/forum/index.php?app=core&module=attach§ion=attach&attach_id=38667 Link to comment
Marcos Martinez Posted January 11, 2015 Share Posted January 11, 2015 I can verify that the new iOS8-version works on my iPAD (iOS 8.1) with Opera web-browser. http://www.DVBViewer.tv/forum/index.php?app=core&module=attach§ion=attach&attach_id=38667 Hello everyone, I am a DVBViewer and RS user who wants to run live TV in iOS devices. I did't know it was that difficult. I knew there was no app fo iOS but I thought the web interface would be enough to run .m3u in external video player. It's not. Doing a bit of google I came across this: http://en.DVBViewer.tv/wiki/IPhone/iPod/iPad_Support but I don't know how/where to install/copy the webinterface files. Can anybody help me with a link or something? By the way, why can't I find that iOS 8 version in the members area? Where did you get it Hansrh? Thanks in advance!!!! Link to comment
