TransEdit Problem
Dear @Tjod,
What is the opinion of this file that you obtained?
Regards.
My assumption was not confirmed.
And if it works in 3.9.5 and not in 4.0.7 I have no idea.
  • 5 months later...
With version 4.0.8, can not still exported.
Pleas post a support.zip
Does not matter !
Because the problem in 4.0.7 and continues in this release.
@griga said, "to be investigated," he said.
What happened ?
4.0.0 and 4.0.1 are exported. Not exported after.
Solve that problem anymore ...
  • 1 month later...
With version 4.1.0, can not still exported. :mad:
no problem here
there is something wrong with you system
you should reinstall windows an redownload DVBViewer and transedit from the members section
or in short fix your system there is no problem in transedit
Sorry for that, but I don't know why it happens on your PC. It was investigated, but there is no evidence for a bug in TransEdit. It works here, for all beta testers and several users without problems.
I have a slow start version 4.1.
Goes somewhere 3 seconds after I click on the icon, then see the main application window.
In version 4.0.8 immediately, less than 1 second.
something has been changed?
Yes, yes mate.
Export okay.
Re-Install DVBViewer
and result ;
I thank the contributors.
Best regards.
  • Like 1
