vramor Posted April 28, 2014 Posted April 28, 2014 I upgraded my DVBViewer many times and had no problem. Now I tried install 5.3.0 upon 5.2.9 (excellent version btw!) and received next messages during installation process. I have never seen such ones before. What do you mean about it? Thanks in advance. Quote
Tjod Posted April 28, 2014 Posted April 28, 2014 There is a Bug in the DVBViewer Pro downloader URL list on the Server. Deselect the Netstreaming Plugin and you shouldn't get an error. Quote
vramor Posted April 28, 2014 Author Posted April 28, 2014 Thank you first of all! But what should I do if I need in Netstreaming Plugin? Quote
Tjod Posted April 28, 2014 Posted April 28, 2014 If you really need that out-dated plug-in, download it manually from the Members Section. Quote
vramor Posted April 28, 2014 Author Posted April 28, 2014 If you really need that out-dated plug-in, download it manually from the Members Section. Thank you for the prompt answer. Couldn't you tell me which of CI plugins is suitable for TBS 5880? Now I choose all of them but it seems to me that the only one would be quite enough. But which one? Quote
hackbart Posted April 29, 2014 Posted April 29, 2014 You only need CI support for Turbosight cards. The downloader script has been fixed so you should also be able to get the files by restarting the tool. Quote
vramor Posted April 29, 2014 Author Posted April 29, 2014 You only need CI support for Turbosight cards. The downloader script has been fixed so you should also be able to get the files by restarting the tool. Thanks a lot! Quote
esenpinar Posted May 2, 2014 Posted May 2, 2014 Thanks a lot, for your answer, I will try again it ,this evening. best regards, Quote
