Service App (iOS8)
There is now a App for iOS8 "Rec. Service"
https://itunes.apple.com/sl/app/rec.-service/id966396749
(It is unlike the Android App or the Windows Phone App it is not completely based on the RS Web API)
To use it you need the "Framework for Rec. Service App" (Members Section) anf the current Recording Service 1.30.1
Extract the zip an place the folder in the SVCweb folder ...\DVBViewer\SVCweb\ios8-1\
And then enter in the App settings as URL username:password@IP-adress:port
no http:/ and no folder name
If you have no password set you need only IP and port. e.g. 192.168.0.5:8089
  • Like 1
I have tried it.
Placed all the files in this folder: C:\ProgramData\CMUV\DVBViewer\SVCweb\ios8-1\ on the Rec. Service machine
On the ipad. Rec. service app Address: username:password@192.168.1.150:8089
Ios version 8.1.1
But i only get a blank screen
Removed the password. Tried, but no luck. It answers (in Danish) "Safari couldn't open page, because the server stopped answering".
http://192.168.1.150:8089 works fine, i get the RS standard webpage
On the RS Machine the folder looks like this:
There is no SVCweb folder in the configuration folder.
You should place ios8-1 in the DVBViewer directory.
Thank you. That Works.
But live TV stops after 5 sec., even if i use Video Bitrate: Low 256 kbit, Encodong Preset: slow and Buffer: 20 seconds
Same for me, video stops after a few seconds.
There I can't help. I don't have a iOS device.
In the German topic are some people with the same problem.
But currently no solution.
Maybe some one else has a idea.
After upgrading OS from 8.1.1 to 8.2 it dosen't stop anymore, but it has huge problems with some channels. The wait cursor just continues spinning. Nothing happens. I think it is the iPad that is to weak to transcode the stream
