caimanonor Posted October 21, 2015 Posted October 21, 2015 hello friends, after 10 minutes of viewing on an HD channel I get the message: "DVBViewer Buffer overrun detected!" how do I fix? Quote
caimanonor Posted October 21, 2015 Author Posted October 21, 2015 hello friend I created the file support.zip now how can I attach Quote
Griga Posted October 21, 2015 Posted October 21, 2015 This error message does not originate from DVBViewer. DVBViewer does not use the Visual C++ Runtime. So it must be an external component like a DLL, a DirectShow filter or such that is used by DVBViewer. Quote
caimanonor Posted October 22, 2015 Author Posted October 22, 2015 hello friend this problem does on HD channels , how do I fix ? can you tell me how I can attach the file support.zip Quote
Derrick Posted October 22, 2015 Posted October 22, 2015 can you tell me how I can attach the file support.zip ..look at the top of the page How to post problems/bugs correctly: Always follow these instructions. Otherwise no one can - or wants - to help you! Quote
caimanonor Posted October 22, 2015 Author Posted October 22, 2015 I did not understand how I can attach the file , I hope for your help or can not use DVBViewer Quote
Derrick Posted October 22, 2015 Posted October 22, 2015 I did not understand how I can attach the file , I hope for your help or can not use DVBViewer Quote
caimanonor Posted October 22, 2015 Author Posted October 22, 2015 (edited) I did not understand how I can attach the file , I hope for your help or can not use DVBViewer ok Edited October 22, 2015 by caimanonor Quote
caimanonor Posted October 22, 2015 Author Posted October 22, 2015 (edited) support.zip Edited October 22, 2015 by caimanonor Quote
Derrick Posted October 22, 2015 Posted October 22, 2015 ..difficult to say. Maybe your machine is not powerful enough for HD. Check the cpu usage. Codec packs are never a good idea. Quote
caimanonor Posted October 22, 2015 Author Posted October 22, 2015 the machine is suitable for viewing HD .. maybe will codecs ? you who do you recommend ? I have to uninstall KLite codec pack Quote
nuts Posted October 22, 2015 Posted October 22, 2015 Try LAV Filter: http://forum.doom9.org/showthread.php?t=156191 And disable/delete all Plugins (i.e. rename the plugin folder) for tests. Quote
caimanonor Posted October 22, 2015 Author Posted October 22, 2015 (edited) after downloading the filter LAV how do I set? Edited October 22, 2015 by caimanonor Quote
caimanonor Posted October 23, 2015 Author Posted October 23, 2015 hello friends I tried the filter LAV 0.66 but I see that worsens vision ( bracket ) . oh I forgot to tell you how to use plugins Quote
Derrick Posted October 23, 2015 Posted October 23, 2015 hello friends I tried the filter LAV 0.66 but I see that worsens vision ( bracket ) . oh I forgot to tell you how to use plugins @nuts asked you already to disable all plugins Quote
caimanonor Posted October 23, 2015 Author Posted October 23, 2015 the problem will be the plugin , how do I fix ? plugin that you have installed ? Quote
nuts Posted October 23, 2015 Posted October 23, 2015 You have to ask the plugin creator for a fix. Quote
