hackbart Posted March 15, 2016 Posted March 15, 2016 (edited) We have released the new DVBViewer Pro 5.6.1 today. DVBViewer Pro 5.6.1In Memoriam - Lars Gehre Please note: Due to a bug in version 5.6.0 / 5.6.1 the "Preset Position" DiSEqC settings does not work correctly and causes unexpected motor reactions. If you need this setting please stay with version 5.5.2 until it is fixed. Change Log DVBViewer Pro 5.6.1 Fix: Recorder: Recording all audio channels as TS did not work anymore (in version 5.6.0). Fix: EVR / Custom EVR: Issues caused by wrong EVR Video Processor handling if the corresponding tweak was switched on. The default is now “off”. Change: Channel Search: After a channel search the Channel Editor automatically selects and shows the first found new channel. Fix: Channel Numbering: Under certain conditions the favorite number was not displayed correctly in “Favorites based OSD navigation” mode. Fix: Channel Numbering: The status bar still displayed a zero-based channel number if the “One based channel and favorites numbering” tweak was switched on. Fix: OSD: After opening the EPG details from the Mini EPG with OSD Green/Yellow and performing OSD Back the last state of the Mini EPG was not restored. Fix: OSD: Assigning channel logos to channels failed in certain cases (particularly concerning audio track sub-entries). Fix: OSD: Browsing left/right in the Mini EPG only worked for the current (played) channel, not after browsing up/down. Added: Main Window: “Hide mouse cursor” tweak (see Tweaker.exe) specifying when the mouse cursor gets hidden in the video area: 0 = never, 1 = only in full screen mode (default), 2 = always (tweak already available in 5.6.0 release). Added: Main Window: New menu item View → Windows Size → Source Resolution plus a corresponding action. It adjusts the size of the main window so that TV or a video is displayed in its original resolution. In case of anamorphic video (non-square pixels) DVBViewer preserves the aspect ratio and adjusts the window size either to the horizontal or to the vertical source resolution (depending on the tweak “Best window size by only changing the height”). Edited March 22, 2016 by Griga 4
