DVBViewer 5.6.2
hackbart
We have released the new DVBViewer Pro 5.6.2 today.
DVBViewer Pro 5.6.2
In Memoriam - Lars Gehre
Change Log DVBViewer Pro 5.6.2
  • Fix: Mosaic View: The Mosaic View did not apply the Options → OSD Appearance → Overscan Adjustment settings correctly and displayed the pictures with a wrong aspect ratio (depending on the OS aspect ratio).
  • Fix: Zoom Settings: The effect of “Stretch vertically up/down” was swapped throughout DVBViewer, including Settings → Zoom, OSD → System → Settings → Zoom and the corresponding actions.
  • Change: Zoom Settings: The handling of the Zoom Setting has been reworked and simplified; several inconsistencies have been fixed. DVBViewer now uses only one set of zoom settings for all aspect ratios, not two separate sets for 4:3 and 16:9 anymore. You may revert to the previous behavior by activating the tweak “Separate zoom settings for 4:3 and 16:9” (see Tweaker.exe).
  • Fix: DiSEqC: The Preset Position setting was reset to 0 on each (re-)loading of the channel list (channels.dat) and each DVBViewer start..
  • Fix: Channel Editor: The additional input elements for the DiSEqC settings “Preset Position”, “Angular Position” and “Extended” were not shown anymore after re-opening the Reception Settings Page.
  • Fix: UPnP Window: On a Windows text size of more than 100% the column widths in the Playback → UPnP Window became wider each time when the window was opened, up to a limit of 10000 pixel. In order to fix this issue DVBViewer Pro 5.6.2 resets the column settings to their default when it is launched for the first time.
  • Added: Hardware Database: Consideration of (known) DVB-C devices requiring the symbol rate to be multiplied by 1000 before it is passed to the driver. “Scan Devices” automatically adds the SRx1000 flag to the hardware settings in this case.
  • Like 12
