AnthonyB Posted April 24, 2016 Share Posted April 24, 2016 Hi I have happily used DVBViewer Pro several years with an internal DVB C card, without any problems. Recently i bought a Hauppauge WinTV SoloHD to run TV on a new computer. There software doesn't match DVBViewer but DVBViewer recognises the USB stick but will not find any channels. I can see that there is a solution given on the German board but I do not read German and Google Translate is not good enough. Can anyone help me please?? AnthonyB Quote Link to comment
Tjod Posted April 24, 2016 Share Posted April 24, 2016 Are you using it for DVB-C, DVB-T or DVB-T2? Pot a support.zip to see how it is detected by the DVBViewer. Quote Link to comment
AnthonyB Posted April 24, 2016 Author Share Posted April 24, 2016 DVB-C support.zip Quote Link to comment
Tjod Posted April 24, 2016 Share Posted April 24, 2016 Start the DVBViewer via stat menu > all programs > DVBViewer > Support > DVBViewer Pro (Debug Mode) and try a channel scan and post a new support.zip Maybe this shows what is happen. Quote Link to comment
Griga Posted April 25, 2016 Share Posted April 25, 2016 Your DVB-C tuner requires a special tweak - see here. The next DVBViewer release will handle it automatically. Till then it has to be done by patching the file hardware.xml in the configuration folder while DVBViewer is closed (see Windows Start Menu -> DVBViewer or Help -> Configuration Folder in DVBViewer). Open the file hardware.xml with a text editor (Notepad), add the line <entry name="SRx1000">1</entry> to the DVB-C tuner section (the second) and restart DVBViewer. That should do the trick. Quote Link to comment
AnthonyB Posted April 25, 2016 Author Share Posted April 25, 2016 Hej Thank You Tjod and Griga for promt attention. The solution works. Funny I didn't find the link here with my board search. Or the solution on the web as I searched a lot before posting. Usually I can find solutions without bothering anyone. AnthonyB Quote Link to comment
