mague Posted July 25, 2009 Posted July 25, 2009 (edited) VDR Retro ist eine Skin im klassischen STB Design. VDR Retro is a Skin with a rather classic STB design. Der font ist im ZIP enthalten. Er ist frei und man kann ihn auch hier downloaden. Einfach runterscrollen zu Roko. / Font is included. Unter Windows 7 ist der font nicht zwingend noetig // Under Windows 7 the font is optional DVBViewer 4.5+ 720p Version last update: 01.01.2012 VDR-Retro-720W.zip NeutrinoCL last update: 09.06.2011 OSD-NeutrinoCL 1.22.zip Weisse Sky Logos + 13th street last update: 20.04.2011 Sky Logos Weiss.zip --- Legacy versions Wird nicht weiter gewartet. / No further maintenance. 16:9 1024x576 version VDRretro_SDW.zip 4:3 720x576 version VDRretro.zip Edited January 1, 2012 by mague Quote
w8andc Posted July 30, 2009 Posted July 30, 2009 (edited) Very nice, colourful and useful skin !! It seems that using EVR renderer in DVBViewer the OSD transparency couldn't be turned off. Even if transparency is set to 0% in the options! Is this a bug or is there an other way to make this happen? Although I like to see the channel logo not above but in the miniepg beneath. Also using the channel logo more often in other OSD screens could be useful. Making use of the "audio symbols" for mono, stereo, dolby 2.0 and dolby 5.1 could be nice. Probably this OSD can be be tweaked some more to make it even better. Edited July 30, 2009 by w8andc Quote
mague Posted July 30, 2009 Author Posted July 30, 2009 Very nice, colourful and useful skin !! It seems that using EVR renderer in DVBViewer the OSD transparency couldn't be turned off. Even if transparency is set to 0% in the options! Is this a bug or is there an other way to make this happen? Although I like to see the channel logo not above but in the miniepg beneath. Also using the channel logo more often in other OSD screens could be useful. Making use of the "audio symbols" for mono, stereo, dolby 2.0 and dolby 5.1 could be nice. Probably this OSD can be be tweaked some more to make it even better. Hello, glad you like it. The transparency is coded into the pictures. To get rid of transparency download the current ZIP. There is a folder no-trans-kit. Copy both pictures into the folder Images inside the OSD folder. I agree on the channel logo while displaying the miniEGP. Moved it down. Where would you like to have channel logos ? A single one of the current channel ? Personally i d like to use them in the recording, timer and currentEPG lists. But so far i did not find any solution to embed them. I didnt know there is more then the "dolby digital" symbol. I ll have a look asap if this is possible. Quote
Tjod Posted July 30, 2009 Posted July 30, 2009 Wegen den Bildern für #TV.audio.pic guck mal hier: http://www.DVBViewer.info/forum/index.php?...st&p=230259 Sonst kann in der Hinsicht auch noch DVBViewer Spy (Mitgliederbereich) hilfreich sein. Das zeigt alle Variablen und deren Werte an. Quote
w8andc Posted July 30, 2009 Posted July 30, 2009 Thank you very much for the quick response and update. Where would you like to have channel logos ? A single one of the current channel ? Personally i d like to use them in the recording, timer and currentEPG lists. But so far i did not find any solution to embed them. I agree. Current EPG: NOW and PROGRAM. In the EPG screen you can maybe make the header / top of that page where the channel name is shown wider, so you have the room to the place and show the channel logo. Indeed you can add something like this in the code: <item> <description>Audio Symbol</description> <type>Image</type> <id>1</id> <x>6</x> <y>403</y> <width>64</width> <height>25</height> <texture>#TV.audio.pic</texture> </item> Add some pictures for the different audio states and they will be shown. I've tested it with some pictures from another OSD. Quote
mague Posted July 31, 2009 Author Posted July 31, 2009 Sound symbols are at work. Tjod's link was selfexplaining. Might take a day or two to create the images though. Quote
karlchen1 Posted August 1, 2009 Posted August 1, 2009 Sieht ja super aus dieser Skin. Schön bunt und mal was anderes. Das einzige was ein bißchen zu groß geraten ist, ist die Recording Infoanzeige. Aber ansonsten gute Arbeit von Dir. Quote
mague Posted August 2, 2009 Author Posted August 2, 2009 sound symbols are available now. I do only have 2.1 sound and SD programs and was only able to test stereo and dolby 2.0. I couldnt find any 5.1 or mono channel. Let me know if mono or dolby 5.1 isnt working. Quote
mague Posted October 19, 2009 Author Posted October 19, 2009 Es gibt jetzt eine experimentelle widescreen version There is an experimental widescreen version now Quote
mague Posted October 22, 2009 Author Posted October 22, 2009 Ich habe ein paar tage frei update bump Senderliste hatte einen kleinen optischen bug. mySeries verbessert Quote
amontillado Posted October 22, 2009 Posted October 22, 2009 Toller skin ! Mann muss sich erst mal kurz daran gewöhnen aber dann ist es eigentlich ein ganz angenemher skin. Mein frau mag es vorallem weil gut zu lesen ist wegen der farbunterschiede Gruss, Ger Quote
mague Posted October 23, 2009 Author Posted October 23, 2009 Toller skin !Mann muss sich erst mal kurz daran gewöhnen aber dann ist es eigentlich ein ganz angenemher skin. Mein frau mag es vorallem weil gut zu lesen ist wegen der farbunterschiede Gruss, Ger Hallo, gut zu hören. Have you thought about changing mySeries plugin so green button is toggling through the different views. Similar to the toggle button on channelview where you can switch through TV, radio and favorites or similar to the red button in myComputer ? Abd maybe put "show fanart" on the red button ? Quote
amontillado Posted October 24, 2009 Posted October 24, 2009 Have you thought about changing mySeries plugin so green button is toggling through the different views. Similar to the toggle button on channelview where you can switch through TV, radio and favorites or similar to the red button in myComputer ? Abd maybe put "show fanart" on the red button ? 1. Reactivated it again (v.16). But keep in mind that Thumbsmall loads the poster, and Thumbbig the widebanners. 2. Red button is reserved for sorting, but can you explain the show fanart a bit... do you mean toggle between showing the fanart or not,.. or showing all available fanart? ps.. these question are perhaps better in its place in the myseries topic? Quote
mague Posted October 24, 2009 Author Posted October 24, 2009 Unterstuetzt jetzt auch myMovies plugin Now supports myMovies plugin update bump Quote
mague Posted November 5, 2009 Author Posted November 5, 2009 update bump Nichts besonderes / Nothing special Einige font Groessen angepasst / changed some font sizes to fit the whole picture Neue, verkleinerte Menues / New, smaller sized menus Quote
mague Posted November 22, 2009 Author Posted November 22, 2009 (edited) update bump Habe viele der Buttons ueberarbeitet Kleinere grafische Anpassungen Reworked many of the buttons Minor graphic modifications Edited November 22, 2009 by mague Quote
mague Posted November 23, 2009 Author Posted November 23, 2009 (edited) Die Version von Gestern hat einige Fehler. Ich lade heute Abend eine neue hoch The version from yesterday is not exactly perfect. I ll upload a new one this evening Edited November 23, 2009 by mague Quote
mague Posted November 23, 2009 Author Posted November 23, 2009 Die Version von Gestern hat einige Fehler. Ich lade heute Abend eine neue hoch The version from yesterday is not exactly perfect. I ll upload a new one this evening Korrekte Version ist online // Proper version is online Quote
mague Posted November 24, 2009 Author Posted November 24, 2009 (edited) update bump Es tut mir leid, aber ich weiss nie genau wann ich Zeit habe was zu machen. Und da patche ich halt wie es kommt. Ist aber der letzte erstmal Noch mehr neue buttons und arrows myMovies plugin spamt das osderror Log nicht mehr -- I am sorry. I never know when i have time to do something with the skin. And so it happens when it happens. But this is the last for now Even more new buttons and arrows myMovies plugin doesnt spam the osderror log anymore Edited November 24, 2009 by mague Quote
mague Posted November 29, 2009 Author Posted November 29, 2009 update bump Alle buttons sind jetzt umgesetzt / Finished the button changes Quote
svensen Posted January 2, 2010 Posted January 2, 2010 Nur mal als kleines Feedback: Dies ist der Skin mit dem größten WAF (nimmt man meine Frau und Ihre Freundinnen als Maßstab) Danke. Jetzt hab ich Ruhe Quote
mague Posted May 9, 2010 Author Posted May 9, 2010 update bump Es gibt nun eine Version fuer 4.3.x beta There is now a version for 4.3.x beta Kleinerer Aenderungen, Schreibfehler verbessert, neue icons im media Center Small changes, corrected typos, new icons for the media center Die Seite fuer MyMovies is nicht ganz fertig. The page for MyMovies is not ready yet. Quote
mague Posted May 10, 2010 Author Posted May 10, 2010 Es gibt einen patch fuer myMiniEPG.xml / There is a patch for mMiniEPG.xml Quote
mague Posted August 24, 2010 Author Posted August 24, 2010 Update miniEPG zeigt jetzt den Timeshift bar an // miniEPG now displays the Timeshift bar Display bei Video und Musik leicht ueberarbeitet // Slight modifications of the music and video display Das Popup Menue ist nun etwas breiter und sollte nun auch laengere Audiospuren leserlich anzeigen // Made the popup menu a bit wider. Should display long audio stream names in a readable manner Quote
mague Posted September 6, 2010 Author Posted September 6, 2010 Update bump Das update ist fuer DVBViewer Beta ! Visueller bug im Listmodus von Musikdateien gefixt // Fixed the Listview bug of music files Es gibt nun ein ZIP mit weissen SKY Logos // There is now a ZIP with white SKY logos. But i think those are probably austrian/german/swiss only. Quote
mague Posted September 21, 2010 Author Posted September 21, 2010 (edited) Update Das Update ist fuer 4.5 RC // The update is for 4.5 RC - Ich glaube nun sind alle Icons und Knoepfe umgesetzt, endlich // I think all icons and buttons are changed now, finally - mymusic und playlist sollten jetzt ordentlich aussehen // mymusic and playlist should look ok now - Kleinere optische Verbesserungen // a few small fixes of the layout - Direkte Unterstuetzung der MircoMedia Skripte // Supports MicroMedia Skripts Edited September 21, 2010 by mague Quote
mague Posted October 9, 2010 Author Posted October 9, 2010 Vorschau einer 720p Version Preview of a 720p version An sich funktional, aber bei weitem nicht fertig It works, but is far from complete VDR-720W.zip Quote
mague Posted October 10, 2010 Author Posted October 10, 2010 (edited) Upgrade Hier ist die 720p Version mit etwas "modernerem" Design. Immer noch flott und laeuft super auf meinem Atom mit GMA Grafik. Here is the 720p version with a more "modern" design. Still fast to navigate. It runs very well on my Atom client with GMA graphics. Edited October 10, 2010 by mague Quote
mague Posted October 15, 2010 Author Posted October 15, 2010 Update - Unterstuetzt nun myScobbler plugin (rechters Bild, 3te Reihe) - Unterstuetzt nun Sleeptimer plugin - Support for myScobbler plugin (picture right side; 3rd row) - Support for sleeptimer plugin Quote
mague Posted October 16, 2010 Author Posted October 16, 2010 (edited) Neue ZIP Datei, da der font gefehlt hat New ZIP file, because the font was missing Klizekleine Aenderung am Recording Symbol in den unterschieldichen Listen Tiny changes on the recording icon in the different listviews Kleine Aenderung an der myscobbler Seite Minor change on the myscobbler page Edited October 16, 2010 by mague Quote
mague Posted October 19, 2010 Author Posted October 19, 2010 Update Hotfix fuer videoinfo (mute, OSD Nachrichten usw. waren kaputt) hotfix for videoinfo (mute, osd messages etc. have been broken) Viele kleinere Anpassungen und Aenderungen. Lots of small changes and tweaks Quote
mague Posted October 23, 2010 Author Posted October 23, 2010 update Ueberarbeitete und vereinheitlichte MiniEPG Symbole hinzugefuegt Reworked and streamlined MiniEPG symbols added MiniEPG und duration fuer die neuen Symbole angepasst MiniEPG and duration modified to go with the new symbols duration zeigt Symbole fuer Video- und Audiospur, sowie die Aufloesung und fps duration shows symbols for audio and video stream and displays the resolution and framerate Das sollte jetzt Ende der Betaphase sein This should be the end of the beta state now Quote
mague Posted October 24, 2010 Author Posted October 24, 2010 (edited) Hi, das 16:9 Symbol war nicht leserlich. Einige der Symbole waren um 1 Pixel verschoben. the 16:9 symbol was unreadable. Some symbols have been wrong by 1 pixel. Bitte das Bild und miniEPG.xml aus dem miniepg patch drueberkopieren. Please copy over the files from miniepg patch. Edited October 24, 2010 by mague Quote
htpc_diy Posted February 1, 2011 Posted February 1, 2011 The OSD skin is very good but I think it will look better if the OSD skin can be changed to be transparent black or transparent blue background. Dear all what do you think? Quote
mague Posted February 1, 2011 Author Posted February 1, 2011 The OSD skin is very good but I think it will look better if the OSD skin can be changed to be transparent black or transparent blue background. Dear all what do you think? Hi, you mean the video background or the brown-ish OSD windows ? Quote
htpc_diy Posted February 6, 2011 Posted February 6, 2011 (edited) Hi, you mean the video background or the brown-ish OSD windows ? Thanks for your reply. I mean the OSD windows. Edited February 6, 2011 by htpc_diy Quote
mague Posted February 9, 2011 Author Posted February 9, 2011 I see.. This is a lot of work since the windows are PNG graphics. You are welcome to redo all the graphics if you want. Quote
mague Posted April 20, 2011 Author Posted April 20, 2011 Hi, in den weissen Logos ist jetzt auch 13th Street. Added white logos for 13th street. No sure if this matters for anyone outside germany... Quote
