Search the Community
Showing results for tags 'dvbviewer crash'.
DVBViewer and Terratec Cinergy S2 stick HD
Jean-Michel posted a topic in DVB Hardware (Digital TV cards)
Hello everybody. I am a new user of the forum. I am using DVBViewer Pro (as a registered user) with a TBS USB device for DVB-C and DVB-T. It works fine, there is no problem. There is none of the issues mentioned below. But I use it too for DVB-S with the new Terratec Cinergy S2 Stick HD. And, even though I can watch and record satellite TV and radio programmes, there are serious issues with this device. First, when I close DVBViewer (with the Cinergy stick plugged), something remains active in the task manager and I cannot relaunch it unless I restart the computer. Second, when DVBViewer Pro is programmed so as to shut down the PC at the end of a recording, it crashes instead. Third, when I try to make a scan for new channels, it crashes (so there are some satellites I cannot tune). I think something is wrong between hardware and software. I attach some screenshots (I'm sorry I'm using a version in French). In the first one, you can see that the stick is recognized in the 'Options' panel. In the second one, you may notice that in the 'Scan for channels' panel, it is not. The third one displays the results of the compatibility tool test. Can you please help me to solve this issue? I am unsure it is a Codec problem. Maybe a software or driver update would be necessary to make the Cinergy S2 Stick HD fully compatible? I am very happy with the functionalities of DVBViewer Pro and I want to keep using it for DVB-C and DVB-T as well as for DVB-S. Thank you for your help.- 1 reply
- 1
- terratec cinergy s2 stick hd
- dvbviewer crash
- (and 1 more)
