Search the Community
Showing results for tags 'hbbtv pc'.
DVBViewer HbbTV Plugin After almost two years of work we finally finished the HbbTV integration in the DVBViewer. The project was developed in cooperation with a Team around Prof. Jäger from the FH Friedberg. What is this all about? (http://www.hbbtv.org/) In short terms it is a combination to deliver additional content from broadcasters to the customer via Internet. This Video gives you a short demonstration how you can interact with your DVBViewer/TV by using this system. http://youtu.be/3ccAEQt6ii4 Many european broadcasters started to use this system in the last two years and a lot others will follow. Since CE-HTML is an important subset of HbbTV the DVBViewer is also capable to play additional CE-HTML based content: How can I get it? If you own the DVBViewer you can grab a license within the keytool, or by using this ordering website:
- 1
