Search the Community
Showing results for tags 'osd skin contrast'.
Hello, here is my newest OSD-SKIN: Contrast. Please note: Contrast contains MR.SkinHelper functionality (BluFuzz - thanks to SnoopyDog). So you need the MR.SkinHelper plugin to be installed: http://www.DVBViewer.tv/forum/topic/38952-osd-skin-blufuzz-mit-optionaler-scrobbler-funktion/ For Contrast you need the font Sony_Sketch_EF and Aeon Main (both included in fonts folder of the skin) installed on your system. Installation: basically like any other skin : The png/jpg-files (images) from images 1 and images 2 folders in the attachments uploaded are to be copied back in the images folder of the OSD-skin folder so that the skin contains only one images folder. In addition following plugins are required: X-skin-plugin and concinnity-plug-in. Also you need miniepgvars-plugin. It shows the sattelite frequenz and strength in mini-epg. Additionaly MyMovies, MySeries, TV Man, neutrinocl, and online are also supported by Contrast. Home images are personal flavour and can be changed of course. Kind regards hoto44 Contrast.zip images1.zip images2.zip
