Search the Community
Showing results for tags 'scan for channels impossible'.
Hello everybody. I have already posted this topic on the forum some months ago, in the "Hardware" section. But I did not receive any satisfactory answer. I was expecting version 5.3 of DVBViewer before posting again. Unfortunately, the current version did not fix the problem below. I am using DVBViewer Pro (as a registered user) with a TBS USB device for DVB-C and DVB-T. It works fine, there is no problem. There is none of the issues mentioned below. But I use it too for DVB-S with the new Terratec Cinergy S2 Stick HD. And, even though I can watch and record satellite TV and radio programmes, there are serious issues with this device. First, when I close DVBViewer (with the Cinergy stick plugged), something remains active in the task manager and I cannot relaunch it unless I restart the computer. Second, when DVBViewer Pro is programmed so as to shut down the PC at the end of a recording, it crashes instead. Third, when I try to make a scan for new channels, it crashes (so there are some satellites I cannot tune). I think something is wrong between hardware and software. Can you please help me to solve this issue? I am unsure it is a Codec problem. Maybe a software or driver update would be necessary to make the Cinergy S2 Stick HD fully compatible? I am very happy with the functionalities of DVBViewer Pro and I want to keep using it for DVB-C and DVB-T as well as for DVB-S. Thank you for your help.
- 2 replies
- crash
- relaunch impossible
- (and 3 more)
