Search the Community
Showing results for tags 'survey umfragen'.
DVD Decoder Selection Removal ● Entfernen der DVD Decoder-Auswah
Tjod posted a topic in DVBViewer Pro Cleanup (en/de)
DVD Decoder Selection Removal Options -> DirectX -> DVBViewer Pro allows to select the audio decoder, video decoder and video renderer for DVD playback separately, which means, other than for TV/Radio and file playback. Is it really required? In case of need it could also (less handy) be covered by configuring Auto A/B conditions or a filter graph preset. So what do you think about removing the separate DVD decoder selection in DVBViewer Pro? Entfernen der Decoder-Auswahl für DVD-Wiedergabe Optionen -> DirectX -> DVD Optionen ermöglicht die separate Auswahl des Audio- und Video Decoders sowie des Video Renderers für DVD-Wiedergabe, so dass andere Komponenten als für TV/Radio- und Dateiwiedergabe verwendet werden. Ist das erforderlich? Bei Bedarf ließe es sich auch (weniger komfortabel) durch die Konfiguration von Auto A/B-Bedingungen oder Filtergraph-Vorgaben konfigurieren. Was haltet ihr davon, die separate Decoder-Auswahl für DVD-Wiedergabe aus dem DVBViewer Pro zu entfernen? -
Radio Window Removal ● Entfernen des Radio-Fensters
Radio Window Removal Radio Window without Radio Window Options -> TV/Radio -> Hide video display area on audio only playback lets the DVBViewer Main Window auto-switch to radio mode, thus reducing the vertical window size considerably. However, it also disables some things that require the video display area, like the OSD, the control bar for file / timeshift navigation, the popup channellist etc. Is the Radio Window really necessary? What do you think? When file / timeshift playback takes place in Radio Window mode, neither the OSD nor the control bar is available for navigation. That's why DVBViewer Pro displays a play, pause and stop button plus a small slider on the left side of the status bar. Play, pause and stop are also available in the Playback Menu, but there is no replacement for the position slider in Radio Window mode. Provided the Radio Window is kept: Are the navigation control elements in the status bar necessary or can they be dropped? Entfernen des Radio-Fensters Optionen -> TV/Radio -> Video-Anzeigebereich bei reiner Audio-Wiedergabe schließen veranlasst das DVBViewer-Hauptfenster, bei Nur-Audio-Wiedergabe in den Radiomodus zu schalten und damit die vertikale Fenstergröße beträchtlich zu reduzieren. Es deaktiviert jedoch auch einiges, das den Video-Anzeigebereich benötigt, wie zum Beispiel das OSD, die Kontrollleiste für Datei/Timeshift-Navigation, die Popup-Senderliste usw. Ist der Radio-Fenstermodus wirklich notwendig? Was denkt ihr darüber? Wenn im Radio-Modus Datei/Timeshift-Wiedergabe stattfindet, stehen weder die Kontrollleiste noch das OSD für Navigation zur Verfügung. Deshalb blendet der DVBViewer Pro im linken Bereich der Statusleiste einen Play-, Pause- und Stop-Button sowie einen kleinen Positionsregler ein. Play, Pause und Stop sind auch im Wiedergabe-Menü verfügbar, aber im Radiofenster gibt es ansonsten keinen Ersatz für den Positionsregler. Vorausgesetzt, das Radiofenster wird beibehalten: Sind diese Kontrollelemente in der Statuszeile notwendig oder können sie entfallen? -
Manual Time Zone Removal ● Manuellen Zeitzonen-Auswahl entferne
Manual Time Zone Removal Usually Windows takes care of the time zone, automatically switches to daylight saving time and back etc. DVBViewer adapts to the current Windows settings if Options -> EPG -> Automatic Time Zone is switched on. "Manual Time Zone" allows for EPG times based on a different time zone than the one configured in Windows Is there someone who really needs the Manual Time Zone setting? If yes please add a comment and tell us why. It would also be possible to remove the setting from the DVBViewer Options and handle it as a tweak (inTweaker.exe), if only rarely used. Entfernen der manuellen Zeitzonen-Auswahl Normalerweise kümmert sich Windows um die Zeitzone, schaltet automatisch auf Sommerzeit um und zurück, usw. Der DVBViewer übernimmt die aktuellen Windows-Einstellungen, wenn Optionen -> EPG -> Zeitzone automatisch einstellen eingeschaltet ist. "Zeitzone manuell einstellen" ermöglicht Zeitangaben im EPG, die auf einer anderen Zeitzone basieren als der in Windows konfigurierten. Gibt es jemand der die manuelle Zeitzonen-Einstellung tatsächlich braucht? Falls ja, ergänzt bitte einen Kommentar und teilt uns mit, warum. Es wäre auch möglich, die Einstellung aus den DVBViewer-Optionen zu entfernen, aber zukünftig als Tweak beizubehalten (in Tweaker.exe), falls sie nur selten gebraucht wird. -
GUI Skin Removal One of the biggest obstacles for further DVBViewer development is the GUI skin support, because it has to be taken into account on every change in the DVBViewer Main Window. That's why we would like to get rid of it. Please note that OSD Skins are not put into question here. GUI Skins are something different. They can be enabled / selected on the Options -> General -> Appearance page. Additional GUI Skins are available in the customer area, but they are out-dated because they are not adapted to the new menu structure introduced in DVBViewer Pro 5.3.0. So what do you think about removing the GUI Skin support in DVBViewer Pro? Entfernen der GUI Skins Eines der größten Hindernisse für die weitere DVBViewer-Entwicklung ist die Unterstützung für GUI Skins, das sie bei jeder Änderung im DVBViewer-Hauptfenster berücksichtigt werden müssen. Deshalb wären wir sie gerne los. Bitte beachtet, dass OSD Skins hier nicht in Frage gestellt werden. GUI Skins sind etwas anderes. Sie werden unter Optionen -> Allgemein -> Aussehen aktiviert und ausgewählt. Zusätzliche GUI Skins sind im Mitgliederbereich erhältlich, aber veraltet, da die Anpassung an die mit DVBViewer Pro 5.3.0 eingeführte neue Menüstruktur fehlt. Was haltet ihr also davon, die GUI Skin-Unterstützung aus dem DVBViewer Pro zu entfernen?
