Flywheel Posted November 26, 2005 Posted November 26, 2005 After updating to the free version bundled with Technisat 4.3.2, at each boot-up my event log contains three SideBySide errors concerning inability to find Dependent Assembly Microsoft.VC80.MFCLOC. Shouldn't this assembly have been distributed with the Viewer? How can I fix this? Thank you. Quote
Griga Posted November 26, 2005 Posted November 26, 2005 at each boot-up my event log contains three SideBySide errors Are Setup4PC/Server4PC running as autostart? Remove the links from the autostart folder. Can be launched manually as well, if needed. Shouldn't this assembly have been distributed with the Viewer? Rather with the basic TechniSat components. DVBViewer doesn't use such a stuff. Quote
