gibman Posted November 28, 2005 Posted November 28, 2005 Hi ! I am wondering if it is possible to query the DVBViewer about different states that would come in handy when programming a remote control in ex. uIce or Girder. My javascript object in uIce is initiated this way. var DVBViewer=Window("DVBViewer.exe\\DVBViewer (TfrmMain)"); I can use DVBViewer for sendmessage and postmessage calls fine. But can I query the DVBViewer engine about it's current state using the above specified object (var DVBViewer). States like; 1) Is OSD being displayed right now ? 1) Is OSD-Channels being displayed right now ? 2) Is teleText being displayed right now ? 3) Is recording in process right now ? + all other possible states. The reason why I want this, is b/c my remote buttons have different functions in different situations. Ex. my "OK" button in normal satellite viewing situation activates the fav. channel list OSD screen. Now we are in OSD mode and it should now act as "OSD select" button. So I need to query the DVBViewer engine wether or not DVBViewer is in OSD mode. /Elo Quote
Guest Lars_MQ Posted November 28, 2005 Posted November 28, 2005 Have a look at the COM-help available in the membersarea. You can't use Post/sendmessage for this. Quote
gibman Posted November 28, 2005 Author Posted November 28, 2005 I downloaded the "DVBViewer COM Interfaces". I don't know what to look for here ? Could you show me one example of this, or direct me to a link ? /Elo Quote
Guest Lars_MQ Posted November 28, 2005 Posted November 28, 2005 look at: isplaying, isvideoplaying, isdvd, osd.isvisible, timermanager.isrecording, windowsmanager.activeWindowID etc. It's all there Quote
