kenmiles Posted November 28, 2005 Posted November 28, 2005 Could you please let me know if there is a command line parameter to start DVBViewer 3.2.5 minimized. Is there a list of parameters published? Thanks in advance. Regards, Kenneth. Quote
Guest Lars_MQ Posted November 29, 2005 Posted November 29, 2005 -x[ActionID] Executes the action (have a look at actions.ini), you can define more than one -x params. -f Fullscreen -m Minimize [filename] play the file -c Standbymode, no channel is tuned, no graph is build. -c[No] The Channel with number [No] is tuned. -c[Name] The first channel named [Name] is tuned. -c:[serviceID] the first channel matching [serviceID] is tuned (have a look at the channellist). -c[Name]:[serviceID] the first channel matching [Name] and [serviceID] is tuned (have a look at the channellist). Quote
chrismxnr Posted November 30, 2005 Posted November 30, 2005 Is there any parameter for tuning radio channels? Christian Quote
Guest Lars_MQ Posted November 30, 2005 Posted November 30, 2005 -c[No]The Channel with number [No] is tuned. -c[Name] The first channel named [Name] is tuned. -c:[serviceID] the first channel matching [serviceID] is tuned (have a look at the channellist). -c[Name]:[serviceID] the first channel matching [Name] and [serviceID] is tuned (have a look at the channellist). Quote
Griga Posted November 30, 2005 Posted November 30, 2005 Have a look here. There you'll find a tool that creates DVBViewer channel shortcuts on your desktop (or elsewhere) with the -c[channelname]:[serviceID] command parameters. Just drag and drop the channels.... Quote
