New DVB viewer user
gvaneynde
using antena for ASTRA and HOTIRD using LNB universal MONOBLOCK(IDLP-40MONO) and Echostar DSB-808 without problem.
on startup yesterday I became green icon... for ASTRA and update transponder. (all seems OK) I wanted to do the same with HOTBIRD... my icon change to red... and I NEVER see it GREEN. after .. I uninstall my SW / remove SkySar 2 TV wihout succes !! I tested also cable, all seems OK but no signal (running on DSB Echstar wihout problem)
What more can I tested ? Is my Skystar 2 TV definitively OUT ?or only setup SW problem? On ZIP file You will find all informations about settings
-_-:bounce:
Thank's for answer
FEHLER.zip
