Teletext greyed out/No interactive services
i.clegg@v21mail.co.uk
My names Ian and I'm from the UK. I've just installed DVBViewer Pro 3.2.5 with Technisat Airstar 2 and I'm having a problem setting up teletext and finding interactive services.
I've set up the data services in SETUP4PC (got the hex addresses from original setup log) but the teletext option on menu is greyed out.
Also there's no interactive services available even though the channels (BBCi for instance are found) is this because MHEG5 isn't supported?
If so can I encourage you by letting you know there's an opensource and free MHEG5 codec/Authoring application available at http://lionet.info/asn1c if this helps.
