T39andcountin Posted December 14, 2005 Posted December 14, 2005 I'm probably doing something wrong here, but I've downloaded the scheduler plugin and it doesn't seem to work for me. Maybe someone can help? I downloaded the DVB Scheduler from the members dowload page, and installed as per the instructions. 1st problem is that the instructions say: 1) Go to to the General Tab of the DVBViewer's Options. 2) Tick the 'Use Microsoft Scheduler' checkbox. But I don't have a 'Use Microsoft Scheduler' checkbox in the options menu. 2nd problem is that I have to update the task list manually, it doesn't do it itself when I close DVBViewer. 3rd problem is that it doesn't work! Task schedular doesn't run the task, and my programs don't record!! Any ideas what I'm doing wrong? I have the following versions: Task Scheduler v1.8 DVBViewer v3.2.5.1032 Windows XP Pro SP2 Hauppauge WinTV 88x DVB-T Tuner/Demod Thanks, Robert Quote
kenmiles Posted December 22, 2005 Posted December 22, 2005 I'm probably doing something wrong here, but I've downloaded the scheduler plugin and it doesn't seem to work for me. Maybe someone can help? I downloaded the DVB Scheduler from the members dowload page, and installed as per the instructions. 1st problem is that the instructions say: 1) Go to to the General Tab of the DVBViewer's Options. 2) Tick the 'Use Microsoft Scheduler' checkbox. But I don't have a 'Use Microsoft Scheduler' checkbox in the options menu. 2nd problem is that I have to update the task list manually, it doesn't do it itself when I close DVBViewer. 3rd problem is that it doesn't work! Task schedular doesn't run the task, and my programs don't record!! Any ideas what I'm doing wrong? I have the following versions: Task Scheduler v1.8 DVBViewer v3.2.5.1032 Windows XP Pro SP2 Hauppauge WinTV 88x DVB-T Tuner/Demod Thanks, Robert <{POST_SNAPBACK}> In the General tab click Extended and that is whwre the 'Use task schedular' check box is then it should work. Regards, Kenneth. Quote
