dk5ras Posted December 20, 2005 Posted December 20, 2005 Hi! I use DVBViewer (3.25) together with a Satelco EasyWatch PC card. So far it works fine, just a few minor problems. I can find no option to turn the antenna amplifier bias on or off, the only way to do this is using the crappy original Satelco software, change this setting and end the sofware; then the driver seems to remember the setting and keeps the selected state while I use DVBViewer. Similar with VHF and UHF channels; the initial channel search (germany/europe) only was able to find the UHF channels being in use her in Nürnberg (34, 40, 59, 60, 66), but no way to find or receive channel 6. When I start the Satelco software, watch a program from channel 6, end the software and start the DVBViewer, then I am able to watch all th CH 6 programs, but no UHF at all. Any ideas out there what the problem could be? I am a total beginner with dvbview, but in case you need further information then just ask Thank you for any hint! Ralph. Quote
