Plugin API
Hi
Im writing plugin and i have a question
in the plugin API i can't see any way to get a trigger response from a singel key press ,only when i select plugin->myplugin with the mouse.
is there a way to add like a shortcut? (like the MDplugin and dvbCore)
if it do not exist, is that somthing that you can put on you "to do list"?
/aTENEr
