hackbart Posted December 24, 2005 Posted December 24, 2005 I wish you all a merry christmas, and just as a small present for all DVBViewer users a new update :yay: Version 3.2.6------------- [*]Add: Actions: Added ACTION_SHUTDOWNCARD (0x00030027) to close down the DVB-Card. Carefull recordings will be stopped, use at own risk! [*]Add: AVI-Playback: Added aspectratio, size, audioformat and framerate detection direct from avi file. [*]Add: DirectX: added EQ. [*]Add: Functions: Added ShutdownCard to close down the DVB-Card. Carefull recordings will be stopped, use at own risk! [*]Add: InputOptions: confirmation dialog assigning a assigned key to another command. [*]Add: InputOptions: confirmation dialog when selecting default. [*]Add: Media-Playback: Added aspectratio detection for 2.35:1 and 2.21:1. [*]Add: MultiAudio TS recordings: the Audiochannel in a multiaudio ts recording can be switched. [*]Add: OSD-Options: Added checkbox to disable channellogos in channellist an timeline to speed up display. [*]Add: OSD-Skin: Added FavouriteEditor page. [*]Add: OSD: Added Favourite editor, can be reached via channelmenu -> contextmenu or OSD-Yellow. [*]Add: PortalChannels: Added support for linked services (Premiere Sport). [*]Add: Recording: All audiochannels can be recorded ts format now. See Setting in Options -> Recorder. [*]Add: Timeshift-Options: If selected keep timeshift you can automatically convert the timeshift file into a (mpeg) recording. [*]Change: COM/Recording: The recording stopped Event is fired now even if it's stopped manually or cancelled. [*]Change: OSD: Serveral internal changes. [*]Change: Recording-Settings: If a recording path is not found the [user]/My Video Folder will be used. [*]Change: Serveral optimizations to lower cpu and memory use. [*]Change: Startup: Optimized loading time. [*]Change: Timeshift: Keep Timeshift works now also with automatic timeshift. [*]Fix: COM: Starting DVBViewer via COM should work now. [*]Fix: DVB-Cards: A dualtuner card should be recognized correctly now. [*]Fix: Languages: Added some missing translations. [*]Fix: Media-Playback: fixed faulty aspectratio detection. [*]Fix: OSD-Controls: Fixed several small problems. [*]Fix: OSD-Music: Fixed small problem with freedb support. [*]Fix: OSD-Skins: Added some missing translations. [*]Fix: Recording-Settings: UNC-Pathnames are now accepted as capture/timeshift folders. [*]Fix: Recording: DVB-Subtitles are recorded in ts format now. [*]Fix: Scheduler-options: fixed wrong path if in Usermode 1 or 2. [*]Fix: VCR: Detection of upcoming recording corrected. [*]Fix: VCR: fixed no channelchange on same transponder when recording with audio plugin. [*]Remove: Removed Dedynamic filter. As you might recognized, the changes are not "that" much stunning, but lets see this version as cleanup and pathfinder for the next bigger release. Christian
Stevie123 Posted December 24, 2005 Posted December 24, 2005 Good Work! One of my Problems with the long starting time and the problems with white screen and long wait time when i switch channels is gone. the loading time is fast and when i switch a channel i see its picture and the EPG immedietly.
Malte Posted December 24, 2005 Posted December 24, 2005 Hi, thank you for the new version. But now, the percentaged status of the broadcast isn't shown anymore in the Mini EPG (see attached image). Do you know a solution for this problem?
Guest Lars_MQ Posted December 24, 2005 Posted December 24, 2005 Yes this is intentional. if you want to see it, simply edit the myminiepg.xml and replace the false with true in the red line <item> <description>progress</description> <type>progress</type> <id>20</id> <x>485</x> <y>392</y> <width>164</width> <height>16</height> <label>#TV.Now.percentage %</label> <subcontrols> <control> <description>background</description> <type>Image</type> <width>164</width> <height>16</height> <texture>progress_background.png</texture> </control> <control> <description>left</description> <type>Image</type> <width>3</width> <height>16</height> <texture>progress_left.png</texture> </control> <control> <description>right</description> <type>Image</type> <width>3</width> <height>16</height> <texture>progress_right.png</texture> </control> <control> <description>mid</description> <type>Image</type> <width>78</width> <height>16</height> <texture>progress_mid.png</texture> <graphicstyp>tile_image</graphicstyp> </control> <control> <description>label</description> <type>Label</type> <width>164</width> <height>16</height> <visible>false</visible> </control> </subcontrols> </item> As for the speedimprovements, there are a lot of optimization in it now. A lot of the stuff should work faster now As Christian said, the main concern for this release was fine tuning and (internal) preparations for the next big steps.
Guest Lars_MQ Posted December 24, 2005 Posted December 24, 2005 One thing @ Stevie123 but this is important for everybody: Clean your channellist, remove every satellite you can't receive, maybe remove channels you will never watch. The less channels in the list the better. The channellist ist involved in most operations (EPG/Favourites) and it takes longer to iterate throught a big list than a small list (duh this was a very intelligent sentence ). The same is of course true for the GE. We spend quite an amount of time profiling the DVBViewer (means looking how long every operation takes) and to put it simple: the main bottleneck is the channellist (or the size of it).
SpecialK Posted December 25, 2005 Posted December 25, 2005 Thank you for the new release. But i don't find the right way to start the DVBViewer via the Webinterface. If i understand you right, it should now be possible. Can you tell me how? Thanks SpecialK
Guest Lars_MQ Posted December 25, 2005 Posted December 25, 2005 I'll have to ask you for a little patience. I'll release an update for the webserver stuff as soon as I find the time.
SpecialK Posted December 25, 2005 Posted December 25, 2005 Ah, ok. I thought i wasn't able to find the right button Then i will follow your Webserver Thread the next time. SpecialK
danielkoch Posted December 25, 2005 Posted December 25, 2005 just downloaded, uninstalled the old version and installed the new one. i can see the osd as in the old version but no tv/radio stations anymore. i have a Medeion BDA DVB-S Card with Twin-Tuner. Grigas 1.7 does still work.
jf2020 Posted December 25, 2005 Posted December 25, 2005 Hi Thanks for this new version. It seems to work very well and to be fast. I just have a very small issue with OSD that is that now when I try to play a recording, the dialog "Resume playback of ###### "No" starts from beginning" both the YES and the NO buttons are highlighted in green while in the previous version just one was highlighted by default. Happy holidays!
e-schrott Posted December 26, 2005 Posted December 26, 2005 Hi Thanks for this new version. It seems to work very well and to be fast. I just have a very small issue with OSD that is that now when I try to play a recording, the dialog "Resume playback of ###### "No" starts from beginning" both the YES and the NO buttons are highlighted in green while in the previous version just one was highlighted by default. Happy holidays! <{POST_SNAPBACK}> The same if you change the channel while timeshift. Yes and No are highlighted
Guest Lars_MQ Posted December 26, 2005 Posted December 26, 2005 Confirmed. A bug But only for the visual appearence of the yes/no dialog.
maliilam Posted December 26, 2005 Posted December 26, 2005 [*]Add: DirectX: added EQ. I can't find it...
Guest Lars_MQ Posted December 26, 2005 Posted December 26, 2005 Menü Settings -> Equalizer or OSD-Menü -> htpc -> Settings -> Equalizer
OKeh Posted December 26, 2005 Posted December 26, 2005 (edited) [*]Add: DirectX: added EQ. I can't find it... <{POST_SNAPBACK}> menu > settings > Equalizer... edit: sorry, i didn't go to the second page Edited December 26, 2005 by OKeh
maliilam Posted December 26, 2005 Posted December 26, 2005 THX, I searched in Settings/Options/DirectX...
hackbart Posted December 27, 2005 Author Posted December 27, 2005 just a small update (hotfix): 1st: Multituner Devices (like the one from Medion) should work now without any problems 2nd: The Equalizer can be disabled optionally 3rd: If you select "unchanged" inside the renderer, the aspect ratio was not 100% correct - but since this was a problem from the first DVBViewer up to now - i suppose it was not really important. Christian
emmel Posted December 27, 2005 Posted December 27, 2005 Thank you once again. One small remark: If I "open file" (*.ts) and select "show subtitles" (*.srt), the DVBViewer window-title is replaced by a running clock, see attached fig. BR
danielkoch Posted December 27, 2005 Posted December 27, 2005 Multituner Devices (like the one from Medion) should work now without any problems confirmed It works again! Thank you for hotfix!
hackbart Posted December 27, 2005 Author Posted December 27, 2005 interesting, the caption time debug line is probably caused by the new vobsub routine. I will take a look on it. Anyhow, it is not really critical Christian
trockentoast Posted January 2, 2006 Posted January 2, 2006 Hey, I saw that "DasVierte" was added to the new Channel- List. But i wonder why there is no "RadioBremenTV" within the List, ... I cant find anything and i searched for it in "Local" and "Regional"! Thx
