Aztech Posted February 3, 2003 Posted February 3, 2003 Hi there, So how do I extract the normal MPEG2 from .ts files produced by piddump? <_< Quote
Klausing Posted February 4, 2003 Posted February 4, 2003 I had a programm that gives the following informations for converting .ts to mpg You find it here. => File is a DVB/MPEG-2 TS (Video/Audio/TTX PES) => make a MPG2 -> SID 0xB5 -> PMT 0x6B refer to these Video/Audio/Text related PIDs : < 0x2FF 0x300 0x301 0x303 > -> PID 0x2FF has PES-ID 0xE0 (MPEG Video) mapped to 0xE0 -> PID 0x6B (PMT) -> ignored -> PID 0x300 has PES-ID 0xC0 (MPEG Audio) mapped to 0xC0 -> PID 0x0 (PAT or others) -> ignored -> PID 0x10B5 (ECM) -> ignored This programm can convert to mpg, pva, vdr, ts2 and its realy fast. The only problem is: its need jave I hope it helps. cheers Steffen Quote
Aztech Posted February 4, 2003 Author Posted February 4, 2003 I had a programm that gives the following informations for converting .ts to mpg You find it here. => File is a DVB/MPEG-2 TS (Video/Audio/TTX PES) => make a MPG2 -> SID 0xB5 -> PMT 0x6B refer to these Video/Audio/Text related PIDs : < 0x2FF 0x300 0x301 0x303 > -> PID 0x2FF has PES-ID 0xE0 (MPEG Video) mapped to 0xE0 -> PID 0x6B (PMT) -> ignored -> PID 0x300 has PES-ID 0xC0 (MPEG Audio) mapped to 0xC0 -> PID 0x0 (PAT or others) -> ignored -> PID 0x10B5 (ECM) -> ignored This programm can convert to mpg, pva, vdr, ts2 and its realy fast. The only problem is: its need jave I hope it helps. cheers Steffen Cheers! Quote
