Luuk Posted January 5, 2006 Posted January 5, 2006 Hi, I just switched from Pinnacle 400e to Nova-S PCI card (using DVBViewer 3.2.6) connceted to a twin LNB-satellite disc. I get no picture/sound or epg at all. Could someone tell me what I should choose under DirectX. With my USB Pinnacle device this showed up there. Now I see only DVB file device; Unicast Network Device and Multicast Network Device. Shouldn't the Hauppage card be listed here? Luuk Quote
Griga Posted January 5, 2006 Posted January 5, 2006 Shouldn't the Hauppage card be listed here? Yes, provided a BDA driver is installed properly. Nova S-Plus DiSEqC support is provided by DVBViewer GE 1.8.1 Beta (see members area, Beta Section) - not yet implemented in DVBViewer Pro. It requires the latest BDA driver 2.4. However, there is only one tester up to now who confirmed that it works - maybe you are the second... Quote
Luuk Posted January 5, 2006 Author Posted January 5, 2006 Ok, but please explain. Why is the Hauppage Nova S listed as being supported when it actually isn't? Where do I get a BDA driver for this card? and finally, didn't you say earlier that the BDA driver doesn't support DiseqC support? Quote
Luuk Posted January 5, 2006 Author Posted January 5, 2006 Griga, I am afraid I am still stuck. I have the Nova-S card, not the Nova-S Plus one and this card does not use a bda driver (its driver is called "ttdvblcd.sys"). Luuk Quote
Luuk Posted January 5, 2006 Author Posted January 5, 2006 Oops, I forgot to say that I did download DVBViewer GE 1.8.1 but without the bda driver the card is not recognised. Luuk Quote
Guest Lars_MQ Posted January 5, 2006 Posted January 5, 2006 Of course not. BDA is essential. Or you use a technisat card or a twinhan, they work native, everthing else is bda. Quote
Griga Posted January 5, 2006 Posted January 5, 2006 The Nova-S is based on TechoTrend design, so probably a TechnoTrend BDA driver will do the job (but without DiSEqC support in DVBViewer yet). Links I've found: http://www.technotrend.de/english/download/download.html http://www.hauppauge.co.uk/board/showthread.php?p=2604 Or this, from the Geman computer magazine c't: http://www.heise.de/newsticker/meldung/64841 Hauppauge dürfte wenig erfreut über TechnoTrends Offerte sein, basiert Hauppauges alte DVB-S-Karte Nova-S doch auf dem TechnoTrend-Design und läuft mit dem kostenlosen Treiber, sodass für Besitzer der Satelliten-Karte nun kein Grund mehr besteht, für den Umstieg auf die MCE Geld für die Nova-S Plus auszugeben. Saying: "Hauppauge will not be pleased by the TechnoTrend offering, since the old Nova-S from Hauppauge is based on TechnoTrend design and works with the free driver, so there is no more reason for owners of this satellite card who want to use Windows MCE to spend money for the Nova-S Plus." BDA is mandatory for Windows MCE....there you are. Good luck! Quote
markymark Posted January 5, 2006 Posted January 5, 2006 Of course not. BDA is essential. Or you use a technisat card or a twinhan, they work native, everthing else is bda. <{POST_SNAPBACK}> I just checked with my Nova-S non-Plus and latest BDA drivers from the Technotrend web page: DVBViewer GE 1.8.1 works, but NO DISEQC !!! Same for DVBViewer Pro 3.2.6 Quote
Luuk Posted January 5, 2006 Author Posted January 5, 2006 Thanks to all of you. I found the bda drivers and they work, but as some of you said, no switching between LNBs, not even with the beta version. At least, as a friend of mine always says, this is better than a poke in the eye with a sharp stick. Luuk Quote
Griga Posted January 5, 2006 Posted January 5, 2006 DVBViewer GE 1.8.1 works, but NO DISEQC !!! Sure. The problem is this: - Microsoft, who created the Broadcast Driver Architecture, didn't specify how to send DiSEqC commands to a DVB-S card via this interface. - Due to this, all manufacturers implement DiSEqC in a different way. - It's difficult to get the specifications from the manufacturers, since they often handle it as a business secret. However, I have some information about the TechnoTrend DisEqC implementation (well, I rather should say "rumours"), and there is already generic support for it in DVBViewer GE 1.8. Generic means, it may be possible to add DiSEqC support by providing additional data in a DiSEqC.ini file. I don't know exactly which kind of data and if it will work at all. But if I find users (not consumers!) who are willing to run some tests, without promise for success.... maybe we get somewhere. Quote
Luuk Posted January 6, 2006 Author Posted January 6, 2006 Griga, I shall be happy to run some tests for you (I have already set up the beta version). Luuk Quote
markymark Posted January 6, 2006 Posted January 6, 2006 Generic means, it may be possible to add DiSEqC support by providing additional data in a DiSEqC.ini file. I don't know exactly which kind of data and if it will work at all. But if I find users (not consumers!) who are willing to run some tests, without promise for success.... maybe we get somewhere. <{POST_SNAPBACK}> I am willing to do so. Also, I am a software developer and have decades of experience in programming. So I can check some things out with the proper advice. Quote
Griga Posted January 6, 2006 Posted January 6, 2006 Ok, fine. I've done some further researches in the meantime, and there are new insights that make it a bit more promising. However, it requires some additional coding, and my family keeps me busy at the moment - you'll receive a PM ASAP. Quote
markymark Posted January 7, 2006 Posted January 7, 2006 Ok, fine. I've done some further researches in the meantime, and there are new insights that make it a bit more promising. However, it requires some additional coding, and my family keeps me busy at the moment - you'll receive a PM ASAP. <{POST_SNAPBACK}> Fine. BTW: I also have a CI/CAM for the Nova-S as well as a Twinhanh Vision DTV, but that one already works very nicely. I am just hoping to get the other card working as well. Having multituner support for both would also be interesting, so once thats on the horizon I can test that as well. Regards, Mark Quote
Griga Posted January 7, 2006 Posted January 7, 2006 Having multituner support for both would also be interesting, Already provided by DVBViewer GE Beta 1.8.1 (no CI support for Twinhan yet). The DVBViewer Pro devs are heavily working on it. A first internal test version will be available soon. Quote
Griga Posted January 13, 2006 Posted January 13, 2006 DiSEqC support for the NOVA-S with TechnoTrend BDA driver seems to work now - already provided by DVBViewer GE 1.8.2 Beta (see members area, beta section)... thanks to markymark. We went through some trials and errors, but finally it did what it was supposed to do. @Luuk: Would be nice if you could run additional tests and confirm that it's working. In the next DVBViewer Pro release it will be added too, I suppose. Quote
