Tomate2 Posted January 5, 2006 Posted January 5, 2006 I´ve an AVERMEDIA DVB-T USB2 and your software seems to be good and cheap so I would like to have coverage to my tvcard. A wish will be also coverage for the remote control. Thanks, Quote
Griga Posted January 5, 2006 Posted January 5, 2006 Is there a BDA driver available? Usually DVBViewer Pro/GE works with all BDA devices. You can check wether it works or not by trying the free TransEdit MMC scanner: http://www.DVBViewer.com/en/index.php?page=downloads Quote
pissedbob Posted January 21, 2006 Posted January 21, 2006 This card is fully supported by DVBViewer using the standard AverMedia drivers (BDA). There's no remote control support yet, though. Quote
