Is it possible to add/remove/modify s. recordings?
antdude
Hello! I was referred by Grigar from http://www.DVBViewer.com/forum/index.php?s...pic=10563&st=0& to here.
I was told that you guys might had developed a way to be able to add/remove/modify scheduled recordings through command line (e.g., telnet/SSH) with DVBViewer Pro? Is this true? I have not gotten the full version yet, but I am considering it if I am able to do this.
Thank you in advance. :(
Edited by antdude
You need to use the com-interface for the pro version, or update setup.ini when DVBViewer is not running in the TE version. Check out this thread http://www.DVBViewer.com/forum/index.php?showtopic=5276 Paul has created a command line script that does that and more.
Thanks I will check it out. I wonder if it is safe to kill DVBViewer.exe through command line if it is already running just to edit setup.ini.
