Go to last channel viewed ?
gibman
Hi there!
I'm using UIce rem. ctrl software to control DVBViewer.
1) How do I change to a specific channel with COM?
2) How do I change to the last active channel just before DVBViewer was closed last time with COM?
The problem is that I start the DVBViewer in UICE not by executing DVBViewer.exe but instead by instantiating a COM reference in javascript in Uice.
ex.
var oDVBViewer = uICE.CreateObject("DVBViewerServer.DVBViewer")
This starts DVBViewer fine, but no channel is tuned in. I have to manually tune in.
If I start DVBViewer by the usual way .. DVBViewer.exe then all is ok.
Ofcourse I could just tell Uice to call DVBViewer.exe as I would do normally.
But once I instantiate the COM object, then one more instans of DVBViewer is launched. Then I have 2 DVBViewer apps running.
See my dilemma ?
/Elo
Edited by gibman
You should be able to connect to a running instance of DVBViewer with something similar to GetActiveObject in python.
The last channel used can be found in setup.xml file. You can use COM to fetch the value with oDVBViewer.GetSetupValue("General","LastSender","")
Someone else can tell you how to tune a channel with COM, I don't know yet.
Thanks for the reply.
Yes, oDVBViewer.GetSetupValue("General","LastSender","") gets me the last current channel in a string.
ex. "3916|C MORE HD (AC3)"
But then again, I see no means of how to change channel within the scope of the COM interface.
anyone ?
/Elo
Try...
Set objDVBViewer = GetObject(,"DVBViewerServer.DVBViewer")
objDVBViewer.TimerManager.AddItem Channel, Date, Start_Time, End_Time, Description, DisableAV, SetActive, Action, At_End, Repeat
Channel = number | name
Date = dd-mm-ccyy (diferent delimiter for your locale)
Start_Time = hh:mm (diferent delimiter for your locale)
End_Time = hh:mm (diferent delimiter for your locale)
Description = free format string
DisableAV = 0 or 1 (false or true)
SetActive = 0 or 1 (false or true)
Action = 0, 1, 2 or 3
0 Record, 1 Change channel, 2 AudioPlugin, 3 Videoplugin
At_End = 0, 1, 2, 3, 4, 5 or 6
0 None, 1 PowerOff, 2 Standby, 3 Hibernate, 4 Close, 5 Playlist, 6 Slumbermode
Repeat = -,T (7 bytes one for each day of the week)
So in your case
objDVBViewer.TimerManager.AddItem Channel, Date, Start_Time, End_Time, "Change The Channel", 0, 1, 1, 0, "-------"
Thanx mrr19121970.
You pointed me in the right direction.
I guess using the TimerManager is a bit of a hack, just to be able to tune in a channel with COM.
If others are interested here is what I did - javascript.
objDVBViewer = CreateObject("DVBViewerServer.DVBViewer")
var oLastCh = objDVBViewer.GetSetupValue("General","LastSender","");
var oNow = new Date();
var sMonth = (oNow.getMonth() + 1).toString();
if (sMonth.length == 1) sMonth = "0" + sMonth;
var sDateNow = oNow.getDate() + "-" + sMonth + "-" + oNow.getFullYear();
var sTimeNow = oNow.getHours() + ":" + oNow.getMinutes();
if (oLastCh.length > 0)
objDVBViewer .TimerManager.AddItem (oLastCh, sDateNow, sTimeNow , sTimeNow , "Change The Channel", 0, 1, 1, 0, "-------");
/Elo
You can also be a smartypants and after your TimerManager.AddItem:
objDVBViewer.Osd.ShowInfoInTVPic "I just Changed The Channel",10000
Another way to start up on the last channel is:
Const DVBViewerPath = """C:\Program Files\DVBViewer\DVBViewer.exe"""
Dim intStatus
Dim WScriptShell
Set WScriptShell = WScript.CreateObject("WScript.Shell")
Dim objDVBViewer
Set objDVBViewer = GetObject(, "DVBViewerServer.DVBViewer")
If Err AND (Err.Number = 424) OR (Err.Number = 429) Then
Err.Clear
intStatus = WScriptShell.Run(DVBViewerPath,2,False)
If Err Then
MsgBox "Problems Starting " + DVBViewerPath
Wscript.Quit(16)
End If
WScript.Sleep(5000)
If Err Then
MsgBox "Unable To Find Running DVBViewer"
Wscript.Quit(16)
End If
End If
