Findus Posted January 7, 2006 Posted January 7, 2006 DVBViewer Pro crashes without any error message from time to time when I am choosing a file from the record menu. I want to watch a recorded file. Never saw this when I select a file through the htpc menu. (DVBViewer is still running but the screen is black and nor mouse or keyboard input is possible) This happens with version 3.24 and 3.25. Not sure if the same happens with 3.26 Have sombody seen the same bahavior? Kind regards Findus Quote
Findus Posted January 9, 2006 Author Posted January 9, 2006 Finally I can reproduce this. It always happens when I delete the ts file manually and afterwards try to watch the ts file via the recordings menu Kind regards Findus Quote
Guest Lars_MQ Posted January 10, 2006 Posted January 10, 2006 I can't reproduce this on my system, but I've changed the responsible routine. In case the file is not physically found, the entry will be removed from the database and of course not tried to play. I've should have done this from the start Quote
Findus Posted January 10, 2006 Author Posted January 10, 2006 Lars, Thanks a lot! Will test it with the next available version. Kind regards Findus Quote
