lout Posted January 8, 2006 Posted January 8, 2006 Plz how to start PIC (Picture in picture) mode thnx Quote
Guest Lars_MQ Posted January 8, 2006 Posted January 8, 2006 OSD-Menu -> Preview or Menu -> Preview Quote
bicas79 Posted January 9, 2006 Posted January 9, 2006 and... how to change the preview channel? Thx Bye You all are doing a great work!! Quote
Gioxy Posted January 10, 2006 Posted January 10, 2006 (edited) Once the OSD was active you can press the remote "blue" button to get a contestual help page... look there... Edited January 10, 2006 by Gioxy Quote
christophe95 Posted January 18, 2006 Posted January 18, 2006 Sorry but doesn't work for me, I have last DVBViewer version, could you help me please ? Thx Quote
Gioxy Posted January 18, 2006 Posted January 18, 2006 (edited) could you help me please ? Of course... but what "doesn't work for you"??? Please be more specific and detailed if you want a useful answer... Edited January 18, 2006 by Gioxy Quote
christophe95 Posted January 18, 2006 Posted January 18, 2006 Ok, sorry. I try with my English.... I test this fonction with DVBViewer GE and it's work perfect, with VRM9. But with pro version, nothing hapend when I select mosaic not preview in menu in small or full screen, I do some test with OSD to and nothing, I read help and try. I saw in GE versions there is 2 files *.exe and *.ini in Plugins folder, but no present in Pro version, so...I put these files in pro version, just to test but nothing. I missed probably something but I don't found. THX for your support and help. Christophe Quote
Guest Lars_MQ Posted January 18, 2006 Posted January 18, 2006 The PIP is integrated into the DVBViewer, no need for external files. You have no OSD also? Quote
christophe95 Posted January 18, 2006 Posted January 18, 2006 Yes , I have and all works perfect exept that, I try with different MPEG video recorder, I have also video from Tv in small screen in Osd but not pip with other channel and no menu than in Ge version. Thx Quote
christophe95 Posted January 18, 2006 Posted January 18, 2006 All Is ok now, I see that not possible on some channels from sat but not from Tnt. Sorry for disturb. And Thx for your help. Quote
lout Posted April 5, 2006 Author Posted April 5, 2006 in osd i press previev but nothig hapend i try to swich diferent codek nothig any help plz Quote
