Support for Nebula?
Jeremiah
I was wondering is there going to be support for Nebula? There are BDA drivers for the card but they don't seem to work with DVBViewer. When I select 'Nebula DigiTV BDA tuner Filter' in options, computer reboots instantly.
Same problem with another app that uses BDA in a similar way. Start reading here:
http://forum.dsp-worx.de/lofiversion/index.php/t175.html
...but no solution, though DCoder is a very skillful and BDA-experienced programmer. Let's hope that Nebula will release a fixed driver soon. Maybe it will help to send a mail to the Nebula support - increases the pressure a bit.
Thanks for the info. I thought that drivers were fine since I got Nebula working with Meedio and ProgDVB.
Last driver release 1.036 was July 2005. BDA drivers are not their highest priority but still...
  • 9 months later...
