sgauntlett Posted January 9, 2006 Posted January 9, 2006 Anyone else a beta tester for Windows Vista? I installed beta 1 and the drivers for the Skystar worked fine. However, just installed beta 2 and the drivers for the Skystar don't work anymore. grrr Quote
sgauntlett Posted July 25, 2006 Author Posted July 25, 2006 Perhaps I'm the only one with Vista...but I doubt it! I've just installed the latest build and the Technisat driver is working. I then installed DVBViewer V3.5 which seemed to install OK but the application doesn't run. Anyone else trying this yet? Quote
Hartwig Posted July 25, 2006 Posted July 25, 2006 Both (Pro & GE) works with windows Vista. More Infos, please... Quote
sgauntlett Posted July 25, 2006 Author Posted July 25, 2006 Vista Beta 2 Build 5472 Skystar 2 PCI DVBViewer application just won't run. Any thoughts gratefully received. MPEG2 Video Decoders: --------------------- CyberLink Video/SP Decoder (PDVD7): 00602000 Microsoft MPEG-2 Video Decoder: 005FFFFF MPEG Audio Decoders: --------------------- MPEG Audio Decoder: 03680001 CyberLink Audio Decoder (PDVD7): 00602000 Microsoft MPEG-1/DD Audio Decoder: 005FFFFF System: ------- DVBViewer Version: 3.5.0.1 (beta) DVBSource Path: C:\Program Files\DVBViewer\Filters\PushSource.ax DVBSource Version: 2.8.0.0 OS: unbekannt (Service Pack 0 v. ) DirectX: 10.0 Memory: 2045 MB CPU: Intel® Xeon CPU 3.40GHz CPUSpeed: 3391 Mhz [Mode] Root=DVBViewer Pro UserMode=1 Setup.xml Quote
lout Posted July 26, 2006 Posted July 26, 2006 Vista Beta 2 Build 5472Skystar 2 PCI DVBViewer application just won't run. Any thoughts gratefully received. MPEG2 Video Decoders: --------------------- CyberLink Video/SP Decoder (PDVD7): 00602000 Microsoft MPEG-2 Video Decoder: 005FFFFF MPEG Audio Decoders: --------------------- MPEG Audio Decoder: 03680001 CyberLink Audio Decoder (PDVD7): 00602000 Microsoft MPEG-1/DD Audio Decoder: 005FFFFF System: ------- DVBViewer Version: 3.5.0.1 (beta) DVBSource Path: C:\Program Files\DVBViewer\Filters\PushSource.ax DVBSource Version: 2.8.0.0 OS: unbekannt (Service Pack 0 v. ) DirectX: 10.0 Memory: 2045 MB CPU: Intel® Xeon CPU 3.40GHz CPUSpeed: 3391 Mhz [Mode] Root=DVBViewer Pro UserMode=1 i just instal ok driver but technisat setup always stop on error -5006 and without that dvbviwer 3.5 not find Hardware all its on vista 5472 Quote
sgauntlett Posted July 27, 2006 Author Posted July 27, 2006 i just instal ok driver but technisat setup always stop on error -5006 and without that dvbviwer 3.5 not find Hardware all its on vista 5472 Ah, now we may be etting somewhere. I also found that the Technisat install failed and I did not know that DVBViewer depended on that to work. Thanks for the insight lout Any workarounds anyone?? Quote
sgauntlett Posted July 27, 2006 Author Posted July 27, 2006 Just tried on older version of Vista Beta 2 Build 5384 and DVBViewer runs OK on that one. I guess something has changed in this latest build. Quote
